Author Topic: Flying J CB550 Cafe Racer Magazine.  (Read 182974 times)
Offline Flying J
Re: Flying J CB550 Atomic #13 Bent Over
« Reply #750 on: April 26, 2013, 02:33:10 PM »
Tring to get the bike to start I have had a few problems. Fuel was leaking from the lines so i chased those down and fixed them. Then my #2 bowl is not sealing so its leaking from the top. I need to drop it and see if the float is set right. I tried to start it and the battery died. THen it would not charge! Freaking $150 battery i messed with it for a bit today and it started to charge. once it was full enough i slapped it in, opened a tappet cover to check for oil and tried to start it. It wont rev up and is running rough but that could be the carbs causing that problem. Im just glad it turned over and didnt make a clunk.
start up cb550
50450
Offline iron_worker
« Reply #751 on: April 26, 2013, 03:14:30 PM »
Sounds like it isn't firing on all cylinders ... Do you have a Dyna ignition by chance?
IW
« Reply #752 on: April 26, 2013, 03:33:26 PM »
IW
First start mate, no filters or anything.... Not all Dyna's are bad either...
Offline Flying J
« Reply #753 on: April 26, 2013, 03:50:59 PM »
It was firing on all four. I felt the pipes after and they were all hot. Ill try again when i get new float bowl gaskets. Oh #$%*! :o as i am typing this i remembered the DYNA is still on test! Im going to go fix that and try round 2. Stay tuned....Be right back.
Offline Flying J
Re: Flying J CB550 Atomic #13 FIRED!
« Reply #754 on: April 26, 2013, 04:32:38 PM »
OH MAN! So much to do. Need front brakes, put on the sprockets and chain.. what else?
Start up 2
50483
« Reply #755 on: April 26, 2013, 04:50:13 PM »
Those pipes are going to sound awesome once you get the rest sorted, you'll have to make a video from behind.... 8)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #756 on: April 26, 2013, 06:18:33 PM »
What else?
Let's start with selling me that exhaust.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #757 on: April 26, 2013, 06:23:56 PM »
Sweeeeeet Dude!
Offline Vinhead1957
« Reply #758 on: April 26, 2013, 06:44:43 PM »
Man that garage looks just like mine!  Sweet!
Offline Flying J
« Reply #759 on: April 26, 2013, 07:22:48 PM »
What else?
You can buy one, Ill give you the guys number... ;)
You would not believe the note these pipes give off. I cant wait to open it up a bit.
So now that it runs. Should i get it on the street and start breaking it in or do a carb sync. I think i answered my own question thinking about it. Ill sync the carbs next unless anybody objects.
« Last Edit: April 26, 2013, 07:27:42 PM by Flying J aka ffJMoore »
Offline Tintop
« Reply #760 on: April 26, 2013, 08:31:46 PM »
Pipes sound great ffj. 8) 8) 8)  What's the ticking you can hear in the vid??
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline brandEn
« Reply #761 on: April 26, 2013, 08:42:41 PM »
What else?
I see what ya did there...
 :D
Offline Flying J
« Reply #762 on: April 26, 2013, 09:49:15 PM »
I dont hear a ticking noise. Might just be the video. Hey Brian what size are the bolts that hold the filter together? I lost mine and need to go get some.
Offline tweakin
  • tear down
« Reply #763 on: April 27, 2013, 04:27:12 AM »
Sounds great!  Man I wish I would have went 4-4 for my 915 build... Someday.
Offline KB02
« Reply #764 on: April 27, 2013, 05:42:58 AM »
4 into 4's are the only way to go.   8)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Syscrush
  • Sold. :(
« Reply #765 on: April 27, 2013, 07:02:14 AM »
Damn that bike just gets better and better!
But do yourself a favor next time and open the garage door before you run the bike. These old machines don't need to run for long in a closed space to give you a mean headache.
Offline Greggo
  • Somebody's
« Reply #766 on: April 27, 2013, 07:19:13 AM »
I vote for a little more break in before a carb sync...too much idling for a carb sync.  Plus, you bench synched them, yea?  They're probably good to go considering the motor's fresh, and most things should be equal on all cylinders.
Offline Godffery
  • Godffery's Garage
« Reply #767 on: April 27, 2013, 07:39:41 AM »
What else?
Hey man, I would be interested in that number.!
 jstephens7@wi.rr.com
Offline Flying J
« Reply #768 on: April 27, 2013, 08:01:14 AM »
I have a roof top house fan that i run with the door open. Moves a lot of air. Sometimes i crack my garage door half way but i never leave it open. To much good stuff in there and i dont like to advertise.
Offline Tintop
« Reply #769 on: April 27, 2013, 12:54:49 PM »
Bolts are SS 6mm button head Allen's ffj.  Can't remember the length, but 15mm should work OK.
77 CB550 Cafe build
Offline Flying J
« Reply #770 on: April 28, 2013, 01:27:39 AM »
What are you guys doing about the breather tube on top of the motor? Leave it open and just put a filter on it? Or does it need a catch can?
Offline Flying J
« Reply #771 on: April 28, 2013, 01:27:57 AM »
« Reply #772 on: April 28, 2013, 04:18:12 AM »
Good job, I dig the pipes too.
I don't like the filter idea on the end of that breather. The filter will eventually plug. What about a small trick catch bottle mounted horizontally under the seat out of sight. Use something with a large enough cap you can run the breather in and a similar sized vent hose out. Then stuff steel wool in the bottle.
Offline Syscrush
  • Sold. :(
« Reply #773 on: April 28, 2013, 05:23:24 AM »
Ok, now I'm jealous of your bike AND your shop!
Offline brandEn
« Reply #774 on: April 28, 2013, 01:30:40 PM »
I used a Power Brake booster check valve on mine
Get them at any parts store.
