Author Topic: Flying J CB550 Cafe Racer Magazine.  (Read 182330 times)
Offline Evening Echo
Re: Flying J CB550 Atomic #13 FIRED!
« Reply #775 on: April 29, 2013, 01:35:29 PM »
I've been spending too much time looking only at 750 builds since joining this forum. That is a beautiful bike you are building! It's given me a heap of inspiration for my own builds.
1924 Raleigh Model 2
1954 Lambretta LD125
1962 BMW R27
1965 Heinkel Tourist
1974 Bultaco Sherpa T125
2002 Ducati ST4S (sold)
Honda CB750F2 (burnt out)
Honda CB750F2
Offline Flying J
« Reply #776 on: April 29, 2013, 05:58:47 PM »
Glad you like it.
My stupid Oil filter is leaking. I used an OEM filter and o ring. I thought that the aftermarket ones were to thin bu i guess this one is too. Im going to look and see if i have a thicker one when i take it apart otherwise i guess i could throw it on the mill and shave it down a hair.
Offline Godffery
  • Godffery's Garage
« Reply #777 on: April 29, 2013, 08:10:50 PM »
Offline tweakin
  • tear down
« Reply #778 on: April 30, 2013, 06:40:53 AM »
+1  I use them on all my bikes, work great, no leaks and a modern filter.
Just ditch that thing and pop this suck'a on there:
http://randakks.com/products/honda-gl1000-gl1100-gl1200-cbx-dohc-4-cx500-and-variants-engine-parts
Offline Flying J
« Reply #779 on: April 30, 2013, 09:22:55 AM »
Yeah but im going to put this bike in a few shows hopefully and i dont want a oil filter sticking off the front of the bike. It just doesnt fit with the rest of the look.
Defiantly much more user friendly though.
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Flying J CB550 Atomic #13 WIRE WIRE WIRE
« Reply #780 on: April 30, 2013, 09:47:43 AM »
Anybody with expierance know what i should set the timing at? I have it set at 35° right now.
49846
ffj
What ignition unit is this?
It looks sweet.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #781 on: April 30, 2013, 09:48:59 AM »
I'd be concerned that spin on auto filters might collide with the pipes.
Offline Flying J
« Reply #782 on: April 30, 2013, 10:32:48 AM »
ffj
It looks sweet.
Dyna 2000
Offline Tintop
« Reply #783 on: April 30, 2013, 02:13:42 PM »
You could use a chrome spin-on filter, some bling for shows.  If a stock filter housing clears the pipes, then a spin-on shouldn't be an issue.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Flying J
« Reply #784 on: April 30, 2013, 02:41:22 PM »
I think the air filter bolts are 5mm not 6mm. Ill bring it with me to the hardware store this time and check but they are not 6mm.  :-\
Offline Tintop
« Reply #785 on: April 30, 2013, 02:46:03 PM »
Could be 5mm.....they came supplied with each filter from ITG.
77 CB550 Cafe build
Offline Flying J
« Reply #786 on: May 01, 2013, 06:39:20 PM »
How do yo route your cable with this filter? Im having issues with it running into the backing plate.
Offline Tintop
« Reply #787 on: May 01, 2013, 07:07:47 PM »
I ran the cable on the outside of the stack.  I'll take a photo tomorrow.
77 CB550 Cafe build
Offline Tintop
« Reply #788 on: May 06, 2013, 04:02:26 PM »
photo ffj -
77 CB550 Cafe build
Offline Flying J
« Reply #789 on: May 06, 2013, 07:29:26 PM »
I dont know why but mine wont fit like that.  :(
Tried to put the front disc on today but the bolts are hitting the speedo drive! Anybody have this issue before?
AND... the exhaust is hitting the swingarm on the left side. I cant get it to clear. I have emailed the maker to see what he suggests.
AND...my oil pump is leaking so i need to get a new seal for the outside cover.
There is a show the 18 that I a going to put the bike in just for fun.
« Reply #790 on: May 06, 2013, 07:52:51 PM »
Try changing the disc bolts end for end.
Offline Tintop
« Reply #791 on: May 06, 2013, 08:13:05 PM »
+1
Also....try sliding the rubber cltuch boot up the cable, and leaving the adjuster slack.  Do the clutch cable stack 1st, then re-adjust the cable last.
« Last Edit: May 06, 2013, 08:18:12 PM by Tintop »
77 CB550 Cafe build
Offline SF
  • I burn gas very well
« Reply #792 on: May 06, 2013, 08:16:17 PM »
you can get the careers counter bored from godffery
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Flying J
« Reply #793 on: May 06, 2013, 09:14:38 PM »
Gosh Dang what would i do without you guys! :) :) :) I flipped the bolts around and they clear!!!  8) I messed a little more with the exhaust and i think it will clear now. just have to see if it has exhaust has leaks at the head now.
As for the clutch cable it has a lot of free lenght to it. Its a custom length cable from motion pro. So the handle adjuster and the clutch side are almost maxed out. I may have to send it back and have it shortened up a hair.
For now Im running pod filters and have a set of velocity stacks on the way. (For show only)
51619
Offline Godffery
  • Godffery's Garage
« Reply #794 on: May 07, 2013, 06:46:46 AM »
Thanks for the reference SF;
Here is a link for what he's talking about:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/
Offline Flying J
« Reply #795 on: May 07, 2013, 07:10:02 AM »
That is on my list of things to do. These rotors don't look great but I want to make sure everything fits and works before I have the cleaned up.
Offline Flying J
« Reply #796 on: May 14, 2013, 11:24:35 PM »
Having issues with the brakes. I think its a combination of it being difficult to get the air out of the lines and a cheap chinese master cylinder. Trying get a decent one from ebay for a decent price.
Offline Godffery
  • Godffery's Garage
« Reply #797 on: May 15, 2013, 04:26:02 AM »
Have you tried "burping" the master?
   If not;
Put the bike on the center stand or Pit stand, remove the reservoir cap, turn the handle bars all the way to the left (your trying to get the master tilted down toward the banjo fitting) this will allow air to bubble up into the reservoir by pumping VERY LIGHTLY on the lever (I've had best results with only slight movements of the lever, (not a full squeeze).  Once you have got all the bubbles out you can with it tilted to the left, then tilt it to the right & repeat. Continue this process left & right till you can no longer get any bubbles;  By then you should start to feel some lever response and can now go to the bleeding the Calipers.
« Last Edit: May 15, 2013, 10:47:14 AM by Godffery »
Offline Tintop
« Reply #798 on: May 15, 2013, 08:44:05 AM »
+1 on Godffery's method.  Try tapping very lightly on the banjo(s) as well, as this will also release trapped air.  I've also had success in turning the front end (so the master is the highest point), then taping the brake lever in the full-on position, and leaving it sit over night.
77 CB550 Cafe build
Offline Flying J
Re: Flying J CB550 Atomic #13 Pissed!
« Reply #799 on: May 18, 2013, 04:14:44 PM »
Took the bike to a vintage show today. SOOOOOO LAME. There were some nice bikes in my class. Here are all the bikes in the calss," Trail bikes, trackers and cafes". There is one trail bike hiding behind mine, 7 bikes total.
 Here are a few better shoots.
Not 1 of the 3 cafe or trackers placed. The 2 trail 70's took first and second! The Rup took 3rd and the Hodaka got a ribbon for some crap. All the trail bikes took home awards and not one for the cafes or tracker. Stupid trail 70s that you can go online and buy every part win over bikes that took actual thoght and hard work to build.
