Hi all,
So the seat is finished with the upholster, I just have to pick it up.
In the mean time, I got more parts in the post. My kibblewhite valve springs and DID performance cam chain arrived from 400fourstore.com. I dropped them off to my mechanic who then took the cylinder head off for more machining (valves seated etc). I had to order some more parts for him. The drive cush rubbers in the primary drive sprocket where rock solid and loose fitting.
So loose fitting that the numbskull previous owner had jammed pieces of hacksaw blades in as shims to hold them snug. Are you kidding me?!Got my brake line from Shaun at Slingshot.
Also a brake light pressure switch.
On first inspection the line seems about one and half inches too long, but I've got bigger problems.
Yep, this problem hasn't gone away. So what I'm thinking now is to find a 90 degree male-to-female fitting that I screw into the master cylinder and then put that banjo into that. I think it'll work whilst not cluttering up things too much.
Something like the 892 or 884 fitting below? Provided the thread and depth are correct of course. Would this work? Where could I get this part? A fittings/brake store perhaps? I'm presuming it doesn't need to be anything special as long as it fits.
Any thoughts?
Rick.
