@ hoodellyhoo: No worries mate, it's as much for you as it is for me to allow people to catch my mistakes. I tried putting the thicker washer on to the top spanner nut as per the suggestion on that other forum but it didn't fit, so I left it off. Maybe I could machine one to fit, but I'll see how it wears first.Hi guys,
So I spent all day Sunday working on the bike. I got the re-taped wire harness on, the swingarm re-built and on, rear shocks and played with the handlebars and switches.
The swingarm was a #$%* to get in. The old bushings that held the swingarm axle in were jammed in. When I finally got them out the grease in the swingarm was almost solid. Getting the new bushings in was extreme difficult. The fit was so tight. I tried heating the swingarm, still wouldn't fit. I tried hammering in the bushings but because they're made from this weird fibre material, they quickly broke. Luckily I was able to use one of the old ones. The other damaged bushing I was able to use a car jack and some soft wood to vice it in. That's how much pressure was required. In the end, the washer/seals pictured above should do enough for me not to worry about the banged-up bushings. Pity about my spray paint job flaking off (forgot to powder coat these), but considering how hard this was to get right, I'll live with it.
Now I forgot to take these out before powdercoating. So the rear shocks bushings were baked in. No matter how hard I banged these with anything suitable, they wouldn't budge. Good thing too as you'll see below,
the replacement set DSS shipped me were the wrong size. As far as I could tell, the old bushings would do just as good a job as the new ones. So I left them in. I'll change them later if I can find the right part, but right now, they'll do I think.
Not sure why DSS would have this listed as a CB400F part when it clearly doesn't fit. Maybe on the later model 400's the changed the width and diameter of the bushings.Update: The bushing are "Cush drive rubber" for the rear wheel. I ordered the wrong part. What I really needed was the "Shock absorber lower mounting bush". Opps.Another wrong part. The new shiny chrome nut on the right is what David Silver Spares listed as a genuine Honda steering stem top nut. Every Honda I've seen of this vintage has the slimmer nut on the left. So whilst I wanted the shiny new chrome, I'll stick with the slimmer old nut. It look better, even with the pitting.
Now that the swingarm is on, I was able to get the new shocks on. Happy days! I ended up getting the cheaper
Red Wing shocks. I know a lot of people say they're rubbish, but for the amount and type of riding I intend on doing, I doubt I'll know the difference.
Plus the Red Wing's came with all the mounting hardware (namely rubber bushings). That saved me having to chase the originals down.
I have no idea what the 4/5 means stamped into the top of the shocks. Anyone here know?
Had a hell of a time getting the powdercoating off the threads. Lucky I held onto the old nuts as I was able to screw those on and off a few times to clean it up.
Part number if anyone cares to know.
You can see where the adjustment is currently set.
This is what the old ones were set to. How do I set the correct setting for me? I'm 6'2" and about 80kgs. Is there a rule of thumb for setting shocks?
Switches. I bought these from
PeakMoto and I cannot say enough good about them. Fast shipping, great packaging and fast on emails. Super helpful and friendly. I ordered some
K&N switches. This indicator/horn/hi-lo switch comes with the 9 pin connector (12-0055CN). However the one they sent me was the 9 loose wires version (12-0055). When I email them about it, Rod from PeakMoto promptly sent me out a new one and said I could keep the old one! Now that is awesome service. Especially over the internet halfway around the globe.
Oh and it has a led high beam indicator light. Sweet.
It comes with two small bits of rubber that fit on that groove to improve grip.
This the 9 loose wires version.
How it will look on my bars. I didn't want to put the grips on because I have to put leavers on first. As you can see, very compact and clean, if not a little modern and racy.
The start/stop/run switch for the right hand side. This is from
K&S also. The 12-0202 to be specific. Yes I could have just made this a small on/off switch on the frame somewhere. However I wanted something that is easy and clear to see as I'm just starting to ride and can get a little confused as to what I need to be doing. This is pretty obvious even for someone like myself. Plus it matches the other and I like the symmetry.
Now this had a little knob that is obviously for mounting it to the bars or throttle or something. Either way, I don't have a use for it. So I cut it off. Famous last words, but hopefully it's for nothing important.
The Motion Pro push/pull throttle in black. I also got this from
PeakMoto. They ordered it in for me pronto. Once again, I would recommend PeakMoto for anything.
Wiring harness! I tried so hard to do this the way it was on the bike originally. But from the handy routing manuals I found here, I guess my CB400F was never wired correctly when I bought it. So I just did it the cleanest and most logical way I could. It would be handy to have another crack at taping the wire harness now that I know where everything goes. To be honest, I reckon' heat shrink wouldn't be too bad. Trouble is getting it over all the large connectors. There must be a better, more cleaner way to do the wiring than like this.
Now this is interesting. I ordered a new condenser from DSS. It arrived, I pulled it out of the box and promptly became confused. I guess 40 odd years of electronics evolution can quite obviously be seen. Trouble is, it only has 1 wire, whereas the original condenser has 3. So I'm confused now. What do I do? Is the new condenser DSS sent me even correct? As you can see below, there is nothing on the box explaining rating or anything. So for the time being I put the old one back on.Update: So this condenser is for the points. What that big silver thing with "condenser" stamped across it is, I have no idea. It's not in the schematics. However I am missing a 'turn signal relay' that is on the schematics but not on my bike. Perhaps this is some kind of aftermarket turn signal relay?I'd love to know if there is other bits of electrics in here that I can replace with newer, cleaner, smaller ones?
In the end the wiring/battery box/electrics came up alright, but I can see why people get rid of the battery box/air filter part altogether. There's got to be a much easier way of doing it. Those black wire just look ugly to me.
Apart from the rectifier, everything else is on the left had side. Can I mount my rectifier on the the spare bracket at the bottom of the electronics panel somehow? Or does it need to be over on the right side by itself for some reason? It's just shame to run a wire all the way around to it and the brake light switch if I can make it look neater somehow.
Done for the day. Actually, maybe for 2 months. I'm going away to the US in a few days until late March. So the bike will probably stay in this state until then. I'm sad, I was really enjoying working on it. However the engine is being rebuilt why I'm away, so that's a positive. Here's what I need to do/get:
- Fork tubes. The ones I have are pitted and for the price, I might just buy new ones. Unless chroming them is affordable, any ideas?
- I need to re-spoke the rims and get new tires. I've been having a hell of a time finding new tires in my size (front: 90/90-18 or 3.00x18 and rear: 110/90-18 or 3.50x18). I love the Dunlop k70, but they don't seem to make them in my size. Cheng Shin make a replica, albeit in dubious quality, but I can't even find that. I'm at the point where I'll take anything with that vintage look. Any help would be much appreciated as mate is in a similar situation with his CB200.
- I need a new chain and guard (I think I need a guard for registration purposes).
- New ignition and coils are in order me thinks.
- Need to re-build front and rear brakes (including machine and drill front disc).
- Spray tank and side covers. Need new pitcock and cap.
- Wire switches, headlight and whatever else is broken.
- Turn singles and stop light. This is going to be fun finding good looking sets of these.
- Side and centre stands put back together.
- Cut down front fender.
- Install inner fender (easy to do, just had it out for electrics.
- Seat. I love the Giuliari style seat, but am not sure if it'll fit a CB400. I made have to shorten it or build my own.
- Rear sets. Ideally I want a set that I don't have to weld on. No ideas on this.
That's everything I can think of. Of course there's going to be parts and action required with the engine too (gaskets, K&N pods etc).
Rick.
