Author Topic: CB550 carb leaking  (Read 2478 times)
Offline glimpsedogg
CB550 carb leaking
« on: May 24, 2009, 04:25:58 PM »
I cleaned out my carbs awhile ago put them back on, the bike ran for a few hours.  then i got sidetracked by a few other projects and the bike sat for a few weeks, now when i try to start the bike it dumps gas out of the number 2 overflow tube.  I've taken the carbs apart 2 times and cleaned out the seat and where the needle sits in very well with the same result.  Today I switched the float and needle from the number 3 carb, which was not leaking, and number 2 still leaks the same.  Any ideas?
Thanks,
David
Offline OldSchool_IsCool
  • Really feeling like an
Re: CB550 carb leaking
« Reply #1 on: May 24, 2009, 05:25:38 PM »
float height?  Maybe there is a flaw in the #2 needle seat?  Maybe still some crud in there?  Drop your #2 bowl, float & needle then try to blow compressed air through the fuel line.  With the other 3 bowls full of fuel, the air should blow through #2 alone.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline jeepster
« Reply #2 on: May 25, 2009, 12:37:33 AM »
Tank clean? Are you running an inline fuel filter?
"An ounce of prevention is worth more if you break it up into nickel bags."
« Reply #3 on: May 25, 2009, 01:19:45 AM »
Is the stand pipe in the float bowl cracked?
Offline glimpsedogg
« Reply #4 on: May 25, 2009, 02:09:19 AM »
the tank is a bit rusted, I am running an inline filter though.  I don't think the stand pipe is cracked, I plugged one end and tried to blow through it.  I'll try blowing some air through the fuel line like old school suggested tomorrow.  Thanks for all the feedback!
Offline Johnie
« Reply #5 on: May 25, 2009, 05:53:33 AM »
When you cleaned out those carbs a while back did you put all the pieces back in the correct carb.  #1 float needle in #1 float seat etc.  You want to keep those together.  Not sure what kind of floats you have there, but I had a brass float leaking.  Check to be sure yours is not sucking in fuel into the float.  Last, install a new float needle and seat if all else is OK.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
timeguy87
« Reply #6 on: September 08, 2009, 08:41:44 AM »
I am having the same problem with the same carb were you able to get this resolve, and if so how?
Offline glimpsedogg
« Reply #7 on: September 21, 2009, 03:21:40 PM »
It seems that the needles were sticking, the bike sat again while I was gone for a few weeks and it started doing the same thing again, so i gave the needles and seats a good cleaning and it is has stopped leaking.  My tank is a bit rusted on the inside so debris may have gotten lodged inside as well.
