Author Topic: '65 Cb160 Forest Assault Bike  (Read 4327 times)
Offline Cowboy
« on: May 24, 2009, 11:54:22 PM »
I started with a craigslist find a bit over a year ago, when this sorry piece of motorcycle history found its way to my garage:
The engine was stuck, but the bike was mostly complete. It was covered in several coats of poorly-applied paint, but the front fender was the only mangled part. I spent a few evenings carefully working the rings and pistons loose. Once they were free, I spent some time checking to see if it would run (and get a freshening) or whether it would get stripped for parts.
It ran, I rode it twenty miles or so, and decided it was worth putting some more money and effort into it. I stripped the bike down to the bare frame, and started cleaning and painting parts. Then re-assembly began:
I found and mounted a set of trials tires, planning to use the bike in my pastures and in the forest nearby:
I spent countless evenings cleaning, polishing and painting parts:
The engine came apart for a fresh set of gaskets and rings. In the end, I had to replace the cylinder block, as the rings had rusted to the cylinder wall and left a large pit, too large to machine out.
No wonder the electric starter didn't work. Someone pulled the guts out of it:
I pulled some miscellaneous parts out of the oil pan, including a master link from a previous cam chain change an o-ring, a broken piston ring and a wrist pin retaining ring:
With the engine reassembled, and mounted in the bike, it was time to paint the tin. Three layers of old paint came off (Original white, then rattle can green, then rattle can black)
The tank went from this:
to this:
After an hour of hammer and dolly work on the front fender, I applied a skim coat of Bondo to most of the fender. Also used some small amounts of Bondo on the side covers.
After spraying tin,  and sewing up a new seat cover, I got the bike reassembled today, and went out for a ride:
1964 Honda CT200
1967 Chang Jiang 750 Sidecar
1970 Honda CB350
1978 Honda CB550
Offline Cowboy
Re: '65 Cb160 Forest Assault Bike
« Reply #1 on: May 24, 2009, 11:58:18 PM »
The bike is unlikely to remain looking this good, once I start riding it in the forest. The CL160 skid plate should help keep the case from getting broken on the rocks, and I plan to mount rubber flaps on the backs of both fenders to preserve thing a bit. Inevitably, though, I'll wind up dropping the bike, and scraping past a few trees.  I give it five years before people start calling it a rat bike!  :D
1964 Honda CT200
1970 Honda CB350
1978 Honda CB550
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: May 25, 2009, 12:06:06 AM »
Nicely done. May the fields of hay treat you well ;D
Offline hoodellyhoo
  • CB350F
« Reply #3 on: May 25, 2009, 09:02:59 AM »
I had forgotten all about this bike. Thanks for sharing! Bike looks fantastic!
Offline mcpuffett
« Reply #4 on: May 26, 2009, 03:18:10 PM »
wow that looks very nice now hope it serves you well ;), cheers Mick.
Offline Flying J
« Reply #5 on: May 26, 2009, 04:23:08 PM »
Great job! Another bike saved.
Offline BeSeeingYou
« Reply #6 on: May 26, 2009, 05:58:07 PM »
Remember to duck for the low hanging branches. ;D
Offline Maxacceleration
« Reply #7 on: May 26, 2009, 07:13:59 PM »
Nice redo Cowboy.
Treat it nicely and save it from the forest.  ;)
Your 45 year old bike deserves it.  :)
Olden is Golden
CR550F RD400 KZ550 KH500
billybobobrain
« Reply #8 on: May 26, 2009, 07:17:00 PM »
muy bueno
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #9 on: May 27, 2009, 12:00:03 AM »
I like it  :D
Even though it will never look this good again after riding, it is all about enjoying what you have done! If you wanted a trailer queen, you wouldn't be riding it.
Plus you can always do it again in a few years  ;)
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline blkvulcan
« Reply #10 on: May 27, 2009, 09:42:49 AM »
Looks great and I bet it is a blast to ride.
Offline Bird76Mojo
« Reply #11 on: May 27, 2009, 10:14:06 PM »
Oh now... Don't go assaulting the forests with that beauty!! What ever happened to following Honda's tank stickers?? Think safety, preserve nature...  :D
Seriously, it's your bike. Do what you will.
GB  ;D
