Author Topic: Parts compatibility between cb750 and cb750a hondamatic  (Read 2459 times)
Offline BudSelect
« on: May 25, 2009, 04:25:35 PM »
To what extent are the parts interchangeable between these bikes, mainly body/frame pieces.  I have a hondamatic i picked up for basically nothing, but the front end(mainly the fork) needs to be replaced.  Could I use the front end of cb750k?  What would this entail?  Thanks
Hondamagic
Re: Parts compatibility between cb750 and cb750a hondamatic
« Reply #1 on: May 25, 2009, 05:40:41 PM »
There is a lot of interchangeability, just not in the transmission. As far as forks go, they will swap right across, they may not look the same , but will fit, and function fine.
Offline BudSelect
« Reply #2 on: May 25, 2009, 06:22:42 PM »
Thanks Hondamagic that answers a lot for me.  Will it require welding, or is it a bolt on deal? Besides the cables, etc.
Hondamagic
« Reply #3 on: May 25, 2009, 06:28:57 PM »
I don't know of any reason why it wouldn't be a direct bolt in. No welding, cutting or grinding required.
