Author Topic: Does Carbon Fouled Plugs Eliminate rejetting as a possible solution?  (Read 6400 times)
Offline ron.cieri.313
Re: Does Carbon Fouled Plugs Eliminate rejetting as a possible solution?
« Reply #50 on: June 07, 2009, 04:40:24 PM »
Well, that is possible but i was going 70-80 in 4th...there may have been a little throttle left at times but I tried to be aware of throttle also...and plus it helped to have a just a little left for safety but maybe that's where I'm going wrong.  I also would ride in 3rd for awhile at 70 which was defintely wot.
I also put the engine in neutral and cut it and coast to the rest stop parking lot so I'm pretty sure i got a good reading there.
mark, I've never adjusted the clutch so I'll look up threads here b4 asking more questions on it.
I thinking of moving up as suggested to 135's but do guys think I should run the test again or is it sufficient do ya' think?..thanks.
Making the world a better place, one motorcycle at a time.
Offline Johnny5
    • CB350F build thread
« Reply #51 on: June 07, 2009, 04:49:22 PM »
Nope, you gotta pull in the clutch and hit the kill switch at the same time all the while going WOT. Then you can coast to a stop with the clutch pulled in.
It's not the easiest thing to do. Takes a few times to get it right.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
