Author Topic: Awe yeah! another chain thread!  (Read 2370 times)
billybobobrain
« on: May 26, 2009, 06:55:37 PM »
So after much searching and much frustration I have decided to anoy the masses with this thread.
First the rules...... ;D
How the hell am I supposed to find a decent chain kit for a 35 year old bike. >:( Half the links in the faq dont work. z1 seems to be a dead end, along with dennis kirk, and every other damn place on the interweb. I just want to buy a damn 530 non o ring, 102 link 46 X 17 sprocket and chain set from the same damn supplier is that to much to ask!!!!!!!!!!!
Forget about the rules!
cb750k
[move]1064 just a little frusterated[/move]
« Last Edit: May 26, 2009, 06:58:16 PM by billybobobrain »
billybobobrain
Re: Awe yeah! another chain thread!
« Reply #1 on: May 26, 2009, 06:59:11 PM »
Please and Thank you ;)
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #2 on: May 26, 2009, 07:08:30 PM »
im gonna lurk around this thread cause I'd like a new chain for my 550 :D
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #3 on: May 26, 2009, 07:15:15 PM »
ok I think this might be able to help you out.   http://www.crc2onlinecatalog.com/Index_Main_Frame.htm  just look under drive parts.
Keep it shinny side up.
Offline Alan F.
« Reply #4 on: May 26, 2009, 07:17:26 PM »
+1 on...  http://www.crc2onlinecatalog.com/Index_Main_Frame.htm   Click on DRIVE PARTS at the left.
http://www.loudfastugly.com/  Click on CHAIN at the left.
Good Luck
-A
billybobobrain
« Reply #5 on: May 26, 2009, 07:27:33 PM »
wow my ulcer just relaxed!
Thanks ;D
Offline Alan F.
« Reply #6 on: May 26, 2009, 07:32:04 PM »
No Prob Dude, cheap chains made in the USA rule.
« Reply #7 on: May 26, 2009, 07:34:51 PM »
lol, I guess it would help my cause to look in the manuals and figure out what type of chain I have. With my current knowledge, my best chance would be to search sites looking for 'CB550 F drive chains'
Kudos to anybody who happens to know the technical specs for a '76 550F chain off the top of their heads!
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: May 26, 2009, 07:37:07 PM »
Look on the Cycle-re-cycle website under "Drive Parts" and then under "Sprockets for Hondas".  It lists the stock sprocket and chain sizes.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #9 on: May 26, 2009, 07:40:10 PM »
yea and they have alot of good parts to help with your resto project.
Offline UnCrash
  • Pass
    • My Blog
« Reply #10 on: May 26, 2009, 07:46:11 PM »
Thanks for these replies!
Offline Philly550K1
« Reply #11 on: May 26, 2009, 07:51:12 PM »
and for 550s, beware the 530 o-ring. the truth is out there. i believe.
verify your sprockets, don't just order the "correct" chain....
-jon
(runs 520 o-ring and sprockets on his 550, and thinks that makes him pretty cool for some reason)
 :P
Offline WFO
  • Will work for powerbands
« Reply #12 on: May 26, 2009, 08:18:37 PM »
Iam currently trying one of these chains for this season, 750 miles later ( zero problems) looks to be wearing just fine i will post a thread at the conclusion of this riding season.
http://www.race-driven.com/motorcycle-off-road-street-/honda/cat_73.html
82 cb650 sc nighthawk - 78 kz 650 b
Offline lordmoonpie
    • Moonpie
« Reply #13 on: May 27, 2009, 04:26:54 AM »
I use www.bandcexpress.com - they have loads in stock and will also machine one off sprockets if you want to switch to a 520 for example....
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #14 on: May 27, 2009, 05:52:21 AM »
Not to be a thread jacker here, but, what years on the 750s came with 530 & 630? I don't see that anywhere in the FAQ? Or anywhere else on here? My 75 750k had a 530 already. Anyone know?
jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Alan F.
« Reply #15 on: May 27, 2009, 05:54:38 AM »
I think they went to a 630 for 77-78
Offline Gordon
  • 750K1, 550K2
« Reply #16 on: May 27, 2009, 06:12:05 AM »
jim
Offline Inigo Montoya
« Reply #17 on: May 27, 2009, 08:02:00 AM »
yes honda did, anything else before that was a 530. A 630 was used since back in the day, chains were not as strong as they are now.
I got chains and sprockets off mawonline.com
Pirate
« Reply #18 on: June 04, 2009, 12:25:06 AM »
-jon
 :P
Hmm, I'm looking to replace the chain & sprockets on my project 550F and would like to switch to 520 so I can run an O-ring chain without the much discussed clearance issues.  Do you mind telling me the sprocket & chain make/model #s so I can just get my local shop to order them in?  Thanks!
Offline GammaFlat
« Reply #19 on: June 04, 2009, 03:18:42 AM »
Here's where you can get a Diamond XMC-1548-M-102P (530 - 102 link).  This site has it for $42.91 plus about $10.00 shipping.
http://kscdirect.com/item/DIA%2BXMC-1548-M-102P/DIAMOND%2BCHAIN%2BCOMPANY_-%250A
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline Philly550K1
« Reply #20 on: June 04, 2009, 10:38:43 AM »
for a stock ratio? they may both exist in off-the-shelf form, but when i did mine a couple years back, i just worked with rebel gears. as i recall, they made me one, and matched it with an existing "in stock" item to give me the desired stock ratio. painless and affordable.
http://www.rebelgears.com/vintagesprockets.html
-jc
-jon
 :P
Offline GammaFlat
« Reply #21 on: June 04, 2009, 02:45:36 PM »
Here's a sprocket "opportunity".   One of the members is having 48 tooth 530 rear sprockets made to have similar specs to the now-discontinued Honda version.
http://forums.sohc4.net/index.php?topic=51563.0
K6
K7
