Author Topic: Ever heard of dynabeads?  (Read 46690 times)
Offline BVCB650
  • Too Much Thin Air
Re: Ever heard of dynabeads?
« Reply #475 on: September 17, 2009, 10:56:35 AM »
More evidence from a believer. Tread wears better than before.
http://www.yotatech.com/f105/dyna-beads-tires-good-stuff-56627/
1979 CB650, 25K miles, recently refurbished
Offline Frankenkit
  • Industrial Strength
« Reply #476 on: September 17, 2009, 10:59:03 AM »
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline BVCB650
  • Too Much Thin Air
« Reply #477 on: September 17, 2009, 11:01:50 AM »
Yet another satisfied customer.
Centrifugal force keeps the Dyna-beads from moving around to where they are not needed, after a tire gets to rotating ...... You can not accelerate a motorcycle fast enough for the Dyna-beads not to work ........ And if you brake to a stop. Guess what ? They just start working again ......... Dyna-Beads Dynamically balance your tire every rotation ! You can not use Dyna-Beads with static weights ....... The tire becomes over balanced ....... The two together work against each other ........
So lets review ....... Anyone that tells you Dyna-Beads don't work, They are full of horse ****. And don't have a minuscule of understanding centrifugal force or better known as the result of rotating mass ......
Better yet they probably need help getting dressed in the morning .......
Offline BVCB650
  • Too Much Thin Air
« Reply #478 on: September 17, 2009, 11:04:20 AM »
Thank you GOD for Dynabeads.
How do they work?
The basic principle behind how Dynabeads work is based on Isaac Newton's First Law of Physics - The law of Inertia.  It states that a body at rest will tend to stay at rest.  When there is a heavy spot on a wheel/tire, it tends to make that spot move away from the center when the wheel spins.  The Dynabeads are unrestrained inside of the tire, so they tend to stay at rest until the side of the tire opposite to the heavy spot comes along and pushes against them.  Once in place against the lighter side of the tire, they balance out the heavy spot.  Any excess beads not needed to counter-act an imbalance simply distribute themselves evenly inside the tire as it spins.  This can occur repeatedly and continuously as needed as the vehicle travels down the road or trail.
For instance, if the wheel/tire picks up any snow/mud/etc that would otherwise cause an imbalance with a conventionally balanced wheel, the DynaBeads will immediately compensate and result in maintaining perfect balance
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #479 on: September 17, 2009, 11:11:30 AM »
Offline BVCB650
  • Too Much Thin Air
« Reply #480 on: September 17, 2009, 11:11:36 AM »
One thing to note....when they put my tire on the balancer, it does NOT spin fast enough for the beads to do their job. They will tell you the beads are not working and want to add weights to it
From a Barbed  Biker.
« Reply #481 on: September 17, 2009, 11:13:59 AM »
Lalalalalalalalalalalalala...lalalalalallallaaalalala
« Reply #482 on: September 17, 2009, 11:17:59 AM »
Offline MickeyX
« Reply #483 on: September 17, 2009, 11:24:23 AM »
Offline MickeyX
« Reply #484 on: September 17, 2009, 11:32:57 AM »
Offline Gordon
  • 750K1, 550K2
« Reply #485 on: September 17, 2009, 11:37:24 AM »
Start hitting this thread, too, please...
http://forums.sohc4.net/index.php?topic=58576.new#new
Offline BVCB650
  • Too Much Thin Air
« Reply #486 on: September 17, 2009, 11:40:01 AM »
You a believer down there on the flat land?
Offline Gordon
  • 750K1, 550K2
« Reply #487 on: September 17, 2009, 11:46:36 AM »
Not getting into it.  I have no desire to replace a system that works perfectly well for my purposes, even if the alternative works just as well or even better according to testimonies by strangers.  Have fun with your pointless agenda.
Offline BVCB650
  • Too Much Thin Air
« Reply #488 on: September 17, 2009, 11:56:28 AM »
Ahhh, thanks for that.
Offline BVCB650
  • Too Much Thin Air
« Reply #489 on: September 17, 2009, 12:04:05 PM »
So lock this sucka. Lotta slingers in here.
Offline BVCB650
  • Too Much Thin Air
« Reply #490 on: September 17, 2009, 12:07:28 PM »
^ Time to punt.
Offline Inigo Montoya
« Reply #491 on: September 17, 2009, 12:11:41 PM »
Ink, that is radioactive waste there!
« Reply #492 on: September 17, 2009, 12:14:48 PM »
And yet the bloated healthcare thread stays open?
« Reply #493 on: September 17, 2009, 12:15:35 PM »
You got a weird fetish there mickey. :D
