Author Topic: Where to look for power issues?  (Read 977 times)
Magua
« on: May 27, 2009, 08:58:00 PM »
I've made a few of these threads before at different times in different forums, so this is a compilation and a place to brainstorm!
Earlier in the year I did a top end rebuild on my 1980 cb400n, camchain, piston rings, valves etc, however, I was still down on power after the work. It has the original exhaust system, and does not appear to be leaking.
I ordered two Keyster carb kits and they seemed to make a world of difference once installed, I could now sit at 120kph etc. From memory I did a carb balance after installing the carb kits. After several weeks commuting I decided to go on a proper ride (100kph vs 70-80kph on the commute), as soon as I was on the open road, my bike felt like it had reverted to its pre-carb refurbished ways, down on power throughout the rev range. I have not figured out why. I attempted to replace the coil to see if it would make a difference, it did not.
Carb balance?
Something inside gone askew?
Where would you look?
The only thing not to be changed in the carbs is the emulsion tubes, apparently the ones in the keystar kit are the wrong sort (according to my local mechanic).
« Last Edit: May 27, 2009, 09:10:02 PM by Magua »
Offline kghost
Re: Where to look for power issues?
« Reply #1 on: May 28, 2009, 12:54:40 PM »
Hows the ignition system other thn the coil?
Timing right? Plugs stay clean?
Airfilter issues?
Good fuel flow?
Stranger in a strange land
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #2 on: May 29, 2009, 04:35:24 AM »
The only thing not changed on the bike is the emulsion tubes in the carbs.... Hmmm
I had Honda CB 125S... Bike started and ran great. Well sorta... At 6000 RPM and above in higher gears 6000 RPM was like a wall. It just stopped delivering power. I knew the jets were clear...
Turns out those little holes in the emulsion tubes were blocked.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
