Author Topic: sourcing rings for a 1978 CB750F Super Sport help....  (Read 2711 times)
Offline motomotard
    • GoGo Garage
« on: May 27, 2009, 09:27:27 PM »
picked up a 78 CB750F Super Sport basket a while ago and i need some piston rings.  I have 3, but need the fourth set and cant find any.  Any help?  Anybody know where i can get em?
pic of my #$%* pile
thanks
Re: sourcing rings for a 1978 CB750F Super Sport help....
« Reply #1 on: May 27, 2009, 10:00:32 PM »
try all the usual in the faq + www.westernhillshonda.net just dont get excited if the web site says they got them with a price, call them as the web is not accurate!!
Offline Flying J
« Reply #2 on: May 27, 2009, 10:48:30 PM »
when i was looking my local honda said they had some.
Clawson Motorsports.
« Reply #3 on: May 28, 2009, 04:37:26 AM »
 I believe the 77/78 K rings are the same but with a different part #. I ran into this problem years ago but somebody on the board from Canada got the # for me.
Offline UnCrash
  • Pass
    • My Blog
« Reply #4 on: May 28, 2009, 05:16:06 AM »
(ghetto subscribe)
I plan to do a rebuild on my F3 motor eventually and am interested if you find a source.  Please post your success!  I'm rooting for you  ;D
Offline Flying J
« Reply #5 on: May 28, 2009, 07:43:14 AM »
If MRieck is right go buy a set of k's, check the measurements, and report back here. Pretty please. ;)
Offline motomotard
    • GoGo Garage
« Reply #6 on: May 29, 2009, 12:56:32 AM »
they guy i got the basket from said the K rings dont work.  they are a little wider than the grooves on the f2 pistons.
ive had the westernhills honda place recommended before, ill check em out.  i was told also that honda no longer makes the F2 rings, so finding them might be a pain.  i know my honda shop said they couldnt get em.
i could just say screw it and go for a 836 kit, but id rather keep my 700 bucks
Offline eurban
« Reply #7 on: May 29, 2009, 03:55:02 AM »
One caution before you spend too much time and $ . . .How are your valve guides?  The Black F motors are prone to premature guide wear.   If you haven't already, check them carefully; it can be an expensive repair.  Also in case you were unaware, the standard 836 kit does not provide enough compression when combined with a F2/F3 head.  You would need a kit specific to the F2/F3 which are more expensive and harder to find.  Have fun!
« Last Edit: May 29, 2009, 03:56:40 AM by eurban »
« Reply #8 on: May 29, 2009, 06:55:25 AM »
 http://forums.sohc4.net/index.php?topic=10546.0   Part #13011-392-004  They work.
Offline Flying J
« Reply #9 on: May 29, 2009, 07:07:21 AM »
Its all out there. And its not hard to find. Its all at this page.
http://www.dynoman.net/bikepages/F2/index.html
if you call the guy he will give you a lesson on the F2. More then you ever needed to know.
even cheaper to replace valves and guides.
http://www.cyclexchange.net/Engine%20Parts%20Page.htm
yeah its expensive at $300 but that cant be much more to replace a K's valves and guides.
Yes the F guides are prone to failure but you can fix it and youll have a better bike, because its an  F! not a K. :D
Offline motomotard
    • GoGo Garage
« Reply #10 on: May 30, 2009, 10:39:48 AM »
im aware of the valve guide problem on the F2s.  already measured mine and all that.  all of my exhaust guides are out of spec, already have the guides and will be doing those next.
neither westerhills or dynoman had the rings.  they have them here http://www.davidsilverspares.co.uk/parts/part_7205/  , probably gonna get em there.  thanks to trevor for the heads up
Offline motomotard
    • GoGo Garage
« Reply #11 on: June 04, 2009, 11:16:42 AM »
anybody know of any reason why 77' super sport rings wouldnt work?
