Author Topic: Weird Blinker Question  (Read 1070 times)
Online Johnie
« on: May 28, 2009, 06:24:27 am »
CB750K1 - Not a big deal, but just wondering why the right side would blink noticeably faster than the left side?  All blinker housings, connections, sockets, bulbs and contacts were cleaned last month.  New battery too.  At least they both blink, just weird why the difference in blinking speed from the left to the right.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline OldSchool_IsCool
  • Really feeling like an
Re: Weird Blinker Question
« Reply #1 on: May 28, 2009, 07:03:31 am »
Are the bulbs the same?  Even thought the connecters were just cleaned, there may be a bit of resistance somewhere causing the difference.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 28, 2009, 07:08:44 am »
When you say the contacts were cleaned, do you mean the switch?  A lot of resistance can be created by a corroded switch contact.
Online Johnie
« Reply #3 on: May 28, 2009, 07:14:33 am »
Yes, I cleaned the switch and used some dielectric grease on it.  I will check the bulbs to be sure they are the same.  Good ideas...
Oshkosh, WI  USA
patrickd
« Reply #4 on: June 02, 2009, 10:46:02 am »
the reason why it blinks faster is because it has a higher wattage bulb on that side. More load on the flasher unit makes the breaker break the circuit quicker. Put the correct bulb in and both will flash the same
Online Johnie
« Reply #5 on: June 02, 2009, 12:16:35 pm »
You guys were correct.  I checked all the bulbs and 3 were #1073 and 1 was #1141.  Changed it out and now they all blink the same.  Thanks
Oshkosh, WI  USA
