Author Topic: Another Sandblasting question  (Read 1527 times)
Offline Otto
« on: May 28, 2009, 03:17:47 PM »
When sandblasting a frame, do you somehow tape off the VIN tag and do the area around it by hand or do you drill out the rivrts? If the rivets are drilled out are there replacements availale?
Thanks
bc
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Another Sandblasting question
« Reply #1 on: May 28, 2009, 03:19:48 PM »
You can do either....
I generally remove the tag and rivet it back on. Any hardware store has them.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline kghost
« Reply #2 on: May 28, 2009, 03:20:11 PM »
I drilled them out.....
I generally replace them with a pop rivet.
Stranger in a strange land
Offline Otto
« Reply #3 on: May 28, 2009, 03:59:05 PM »
Thanks guys,
Did you guys ever try chemical stripper on the frame vs. sand blasting? The Chemical stripping doesn't work very well on the motor clear coat... for me anyway..
bc
Otto
garagedoreen
« Reply #4 on: May 28, 2009, 04:16:37 PM »
chemical is way messy. just take it to a good sandblaster and they will use the right stuff and should be clean when you get it back.
