Author Topic: best tank sealer available?  (Read 16013 times)
Re: best tank sealer available?
« Reply #25 on: December 03, 2016, 03:43:43 PM »
Had kreeme liner in tank when I bought the bike, peeled a few weeks later, and I did the POR-15 and it worked great. The kreeme may have been peeling due to bad prep by PO, but I will never know
Yes it was bad prep. I Kreemed my tank MANY years ago and it's still fine. Kreeme doesn't deserve the bad rep it gets, the applier deserves the bad rep.
« Reply #26 on: December 03, 2016, 03:50:39 PM »
 Caswell worked well on my glass tank. I could see inside through the bottom and wasn't getting coverage so I mixed the other 1/2 and dumped it all in.
  Make sure your choice of liner is OK in fiberglass. Caswell is.
« Reply #27 on: December 03, 2016, 05:03:22 PM »
I have Caswell in a couple tanks. Simple to install it.
Offline innovativems
    • Innovative MotoSports
« Reply #28 on: December 16, 2016, 06:56:39 PM »
i've used por15 and caswell.  hands down caswell is my go to
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #29 on: December 16, 2016, 07:16:52 PM »
I like POR.
« Reply #30 on: December 16, 2016, 07:23:25 PM »
Caswell - no substitute.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #31 on: December 17, 2016, 10:21:44 AM »
Red Kote will not work. It is not safe with ethanol gas and I do not recommend it. I lined my CB750 Supersport tank and within 3 months over half the Red Kote had dissolved.
I had the exact opposite experience with red kote.
I did some de-rusting first with metal rescue.  Poured in half the quart of red goo.  Did the tank rotisserie while it set up.  Gave it a day to dry before pouring in the second half of the can and repeating the process.  Set it out to dry for a while.  Giving it the recommended sniff test before exposing it to gas.  Even when i thought I couldn't smell the chemical, I gave it another day or so just to be safe.
Havent had any trouble.  And no more rust in the carb bowls!
Offline grcamna2
« Reply #32 on: December 17, 2016, 11:07:07 AM »
The prep and cure time is 'key'.I found that w/ RedKote you need to get the inside of the tank BONE DRY like the desert.. after fully cleaning/washing it out.
