Author Topic: Wiring help needed...STAT :P  (Read 727 times)
Offline schwebel
« on: May 29, 2009, 08:25:51 AM »
So my 350f has been running like a champ. Last night I put her into the garage and it just died right before I turned the key off. I checked the main fuse, and its fine (even bypassed it to make sure). The battery has plenty of juice. Turn the key...nothing. So I pulled the headlight off and a wire from my right handle bar control has no home. It is Black with a White stripe and has a female connector. I cannot find a lone male connector inside the headlight. The other two solid black wires,... one goes to another black. And the other goes to a double connector with a Black with White stripe, and a Solid black, but no home for my B/W comming from my handlebars? What does the B/W connect to? Anyway to trace it from the other end.
Offline new2novas
Re: Wiring help needed...STAT :P
« Reply #1 on: May 29, 2009, 08:38:11 AM »
that is for the power to the coils....a black wire goes up to the kill switch and comes out a blk/wht and ends up at the coils....check the faq for a wiring diagram
75 cb750F
