Author Topic: What is the best way to remove gasket residues?  (Read 3287 times)
Offline nobrake
« on: May 30, 2009, 07:40:13 AM »
I tried petroleum, paint remover, paint thinner....also tried scrapping vertically
with a razor blade.......
Tips?
Pleas don't say "patience and elbow grease".
Offline Patrick
Re: What is the best way to remove gasket residues?
« Reply #1 on: May 30, 2009, 08:18:27 AM »
Most auto parts stores sell aerosol gasket remover. I've had some luck with it. Spray it on, let it sit, scrape it off.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline kghost
« Reply #2 on: May 30, 2009, 08:41:56 AM »
Have someone else do it?   ;D
Seriously....try MEK on a rag
Stranger in a strange land
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #3 on: May 30, 2009, 09:05:38 AM »
I tried Aircraft paint stripper and permetex gasket remover and neither worked. Had to do the razorblade thing, and it took the better part of a day. Sorry.
1974 CB550
Forever West
Offline Alan F.
« Reply #4 on: May 30, 2009, 09:57:43 AM »
How long did you let the Permatex spray type gasket remover sit before trying to scrape?  Maybe letting it sit longer and reapplying would do it?  That's strong stuff.
-A
Offline swan
« Reply #5 on: May 30, 2009, 12:04:51 PM »
+1 on Permatex gasket remover. Careful with overspray, it will remove paint too
1975 CB400 F cafes, 1974 CB750 K4 Cafe, 1966/1976 Triumph/ Norton Triton Cafe and 1962 DBD34 BSA Gold Star Clubman.
CB750 build http://forums.sohc4.net/index.php?topic=52551.0
Offline Mdub
  • Xspurt
« Reply #6 on: May 30, 2009, 12:08:39 PM »
A green 3M scuffy pad on a ro-lock disc mandrel in the hand drill makes short work of it. :D
X= an unknown quantity
Spurt= a drip under pressure!
Offline VTCBike750
« Reply #7 on: December 30, 2011, 08:59:58 PM »
Think Ill try this method. How harsh is the green 3M pad on the aluminum? Do I need to be super gentle or just go for it?
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
« Reply #8 on: December 31, 2011, 01:00:03 AM »
finesse and elbow grease,or take it to one of those drive through gasket removal places.
« Reply #9 on: December 31, 2011, 03:27:37 AM »
I'm with the 3M strip disc post, I use one attached to my 7 inch sander/polisher and it makes old gaskets disappear! Hey Dave, where are these drive thru gasket removal joints? What a great idea for a franchise! ;D
Offline Jeff.Saunders
  • Obsessed by Old Motorcycles
« Reply #10 on: December 31, 2011, 03:39:55 AM »
The best scraper I've found is the Goodson 'Super Scraper'.
http://www.goodson.com/store/template/product_detail.php?IID=8905&SID=1729970ee0691d7016327a6f4a906dfe
These have a precision ground square cut carbide tip - VERY tough and a lot safer than razor blades.
When I spoke with them at the DealerExpo earlier this year, they also plan on a narrower version for smaller engines.
Offline MoMo
  • Ride like you're invisible
« Reply #11 on: December 31, 2011, 04:20:16 AM »
I agree with Terry-that 3m attachment made mincemeat out of a very old, rock hard 550 gasket...Larry
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #12 on: December 31, 2011, 06:43:03 AM »
Those 3M Roloc discs are great on steel or cast iron surfaces but can ruin an aluminum sealing surface in a heartbeat. On aluminum, you need to use the least coarse grade available, use very light pressure, and keep the disc moving on the surface. Don't hold it in one spot to remove a stubborn piece of gasket, or you'll end up with a surface that won't seal, even with a new gasket. I personally stopped using Roloc discs on aluminum surfaces and stick with Jasco Stripper and a scraper. Paint on a heavy coat, and let it sit for several hours before scraping. I've also had good luck with Easy Off oven cleaner. If you read the fine print on a can of "gasket remover", you'll find it's designed to remove gasket cements and adhesives. It doesn't actually do much to soften rock-hard old gasket material.
Stu
MCN DTF
Offline VTCBike750
« Reply #13 on: December 31, 2011, 08:16:39 AM »
Wait! These exist? HolyS@#*! I need to find out if theres one in VT.  :)
Thanks for the tips guys. Having never done it, I wanna learn from your experiences and not jack anything up.
-Adam
Offline chewbacca5000
  • I polish covers!
« Reply #14 on: December 31, 2011, 01:37:44 PM »
I've done a little of this lately and have had good luck with Berryman B-12 chemtool in the spray can.  It also does a fairly decent job of dissolving carbon.
« Reply #15 on: December 31, 2011, 01:55:04 PM »
Yeah, I'll go there as soon as I get back from my snipe hunt.   ;)
Offline VTCBike750
« Reply #16 on: December 31, 2011, 05:23:52 PM »
I love snipe hunting!
-Adam
« Reply #17 on: December 31, 2011, 05:36:09 PM »
Stu
Yep, sorry mate, I didn't know what a Roloc disc was when I posted here earlier, this is the 3M paint strip disc I use, I've used it on the last 4 engines I've built over the last 7 years with no oil leaks at all. Cheers, Terry. ;D
http://www.shop3m.com.au/Clean_and_Strip_XT_DC_Disc_XT_DC_125mm_x_22mm_p/xc000702065.htm
