When you changed the oil, did you change the oil filter? If you did, did you put the spring on correctly? So in order it would go - front of engine - oil filter - metal washer - spring - oil filter housing with the bolt through the middle. If the spring is on so it sits against the front of the engine, this may cause some problems for oil feeding and maybe pressure or something to have it come out of the tank breather and on the back wheel. It might be worth checking if you are not sure.
