Author Topic: honda nighthawk 84 650 help running hot  (Read 2507 times)
dennismsaunders
« on: May 31, 2009, 09:28:17 AM »
i just cleaned carbs all new seals,but i have a i think problem with the 2 cylinders #3&4 running 40/50 degrees hotter then# 1/2 side of bike?
any one got any tricks to tune i do not have a manometer,maby i can rent one?
thanks and this looks to be a great forum.
thanks dennis
Offline Soos
Re: honda nighthawk 84 650 help running hot
« Reply #1 on: May 31, 2009, 09:44:23 AM »
Are you sure you posted this in the right area?
If you are in the US, the '84 is likely to not be a SOHC.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline cb650
« Reply #2 on: May 31, 2009, 10:16:19 AM »
The inner 2 will runn hotter than the outers wont they guys?
Offline Soos
« Reply #3 on: May 31, 2009, 02:33:37 PM »
Yup.
Even the Clymer manual I have states that.
You can do a shadetree mechanic trick and run slightly different heat range plugs on the 2 inner cylinders though.
Not sure if it's really worth it though.
l8r
-=≡ Soos ≡=-
dennismsaunders
« Reply #4 on: June 03, 2009, 03:36:03 PM »
please excuse me im stupid,your right there are 2 cams,thanks
so as i understand  a 50 degree differance is normal? cool i thought i had the carbs screwed up
can any one tell me a normal temearture??after about 5 or so minutes stand still
with some high reving im getting about 240 ,im using a inferred gun
but again it seems to be hotter on the right side then the left?
thanks alot guys
if you cant tell im pretty new to cycles
i cannot belief the amount of onfo and personal help on this site
thanks again
Offline cb650
« Reply #5 on: June 03, 2009, 03:45:28 PM »
Yes you are in the "other bikes" section so pefectly fine.  Soos was most likely cranky cause I sent him the wrong wheel ;D.   I might be able to borrow a gun and check mine this weekend.
Offline martino1972
  • and still a expert welder,period...
« Reply #6 on: June 03, 2009, 03:56:28 PM »
checking your sparkplugs will tell ya if the jetting is right.....
you will have to do a "pug chop" for that.......ride the bike,give her WOT for a bit(doesn't have to be 5th gear,as long as theirs a good load on the motor) then pull in the clutch and kill the engine right away....freewheel back to your shop/garage,let cool down for a bit and then pull your spark plugs out......by looking at thew color of the tips you can see how she is jetted.....
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
Offline Soos
« Reply #7 on: June 04, 2009, 11:28:59 AM »
no it took glen a day or so to move the thread to the proper place....
And yes I was having a bad day, nothing to do with you 650.(BTW,  PM on the way 650)
Sorry for snipping at you there..
Oh, and as far as a 50 degree difference, my cb650 has the inner two running about 40-45 degrees hotter than the outer two. depending on the RPM I hold the motor at.
So (IMO) nothing too major there.
My cb650 is a '79 with lots of mods, ignition, pistons, carbs, oil cooler, and on, and on...
Although a plug chop can't hurt by any means though.
Lots of threads on the subject.
l8r
-=≡ Soos ≡=-
Offline Hush
« Reply #8 on: June 05, 2009, 02:22:34 AM »
Honda built a DOHC 650? don't think they got to New Zealand!
Offline cb650
« Reply #9 on: June 05, 2009, 05:35:37 AM »
Yes in the states it was made from 83 to 87 or 88.  Have seen a 87 but not shure when the stopped.  Shaft drive 6 speed.  A couple of the new members on the 650 site posted pics of them.
