Author Topic: 550 Igition Timing Problem  (Read 1034 times)
Offline phillip56
« on: May 31, 2009, 10:33:14 am »
I'm really confused now.  I went to check the timing on my 550 and discovered the 2-3 set were bang on but the 1-4 were about 25 degrees advance.  I bought a new set of points and condensers and replaced them but got the same result. I thought maybe I go the cam backwards on the advance but after I switched it was way worse so I put it back to the original position. I set the point gap to .016 so I decided to close up the gap and that helped a bunch and now it's about 10-15 degrees advanced.  Any ideas about what the problem is.  I've got the plate all of the way in one direction and this doesn't seem right.
Offline kghost
Re: 550 Igition Timing Problem
« Reply #1 on: May 31, 2009, 11:53:22 am »
Did you set the timing on 1-4 First?
Stranger in a strange land
Offline mikethejeepguy
« Reply #2 on: May 31, 2009, 12:03:51 pm »
Would this help? http://oldmanhonda.com/MC/Rtiming.html
Are you using the points plate for adjusting 1-4 and the breaker arm for 2-3? On mine, I had to somewhat "compromise" between timing and points gap to tweak the timing when I ran out of adjustment. A week later I went electronic. :)
'76 Honda CB550F, Dana-S'd, Uni filtered, HID'd, LED'd, and mildly cafe'd with many plans still.
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #4 on: May 31, 2009, 12:30:19 pm »
Just   got done reading that link and man does it help. I finally get how adjust the points now.   But question  when setting up cylinders 2,3 do you have to put the timming gun on cylinder 2 or just leave it at 1?  still don't understand that part.
Keep it shinny side up.
« Reply #5 on: June 01, 2009, 06:44:35 am »
Awesome! Glad that link helped. Yup, you have to switch plug wires on the timing gun to do 2/3. I do my 1-4 from my No. 1 wire and 2-3 from my No.2 wire. :) Did you get it timed? It's amazing how much smoother everything runs after. :)
