Author Topic: 76 cb750f exhaust on the ground  (Read 1735 times)
rachsrib
« on: May 31, 2009, 07:45:24 PM »
Hey, took my first ride today on a bike I picked up for $150 !!  However the exhaust are definitely not for this bike. Every bump I hit I could just here the 4 into 2 pipes hitting the ground and forget about any kind of turning. There are not even any mounting brackets.  But anyway I really like the 4 into 2 "british" kind of look and was wondering if anyone knew where I could get a set of pipes for my 76 250f. Every thing I find seems to be for the 79 and newer models. Would a 79 and newer pipe set up work on the 76?
Thanks
Steve
Offline BeSeeingYou
Re: 76 cb750f exhaust on the ground
« Reply #1 on: May 31, 2009, 10:47:17 PM »
How about a picture.  That sure does not sound right.  The 79 is a DOHC engine so I am not sure it would fit.  The CB750F's are set up for a 4 into 1 system and there are after market ones available.  You may have to make up some type of mount if you want something else.
rachsrib
« Reply #2 on: June 01, 2009, 12:01:30 PM »
Ok per request here are some pictures
The left side exhaust hangs way down and as you can see there is just room enough for the toe of a shoe, the Right side exhaust seems to fit pretty nicely.  The two mufflers look different.  I guess im just wondering if anyone know of an exhaust that would fit the 76 cb750f and allow me to keep the look of the 4 into 2?
Thanks
Offline Inkscars
  • grumpiness comparable to an
« Reply #3 on: June 01, 2009, 12:03:58 PM »
Your strap is broken off. Throw a hose clamp on it or fabricate something.
81 Hardly Davisson
Offline MacM2010
  • Nobody Special
« Reply #4 on: June 01, 2009, 12:09:58 PM »
+1.  Those pipes look pretty decent, the left side just isn't attached properly.
If you really want a change, Benji's Cafe Racers has 4-2 pipes for a 750.  Of course, your $150 bike will quickly become a $1000 bike.
One day, I will put up a signature.
rachsrib
« Reply #5 on: June 01, 2009, 12:17:01 PM »
I actually have the exhaust mount clamp thing for the left side however the pipe angle is downward so the mount doesnt even come close I dont think I can leave the left as is since it is so close to the ground. I almost seem like I have 2 right side mufflers. BTW would this system fit a 76 even though it says 79? http://www.motorcycleproshop.com/detail.asp?product_id=001-2609
Thanks
Offline Inkscars
« Reply #6 on: June 01, 2009, 12:18:47 PM »
It seem like maybe it's stretched from hanging, You may have to do some massaging, but you could DEFINITELY get it to move a couple inches with some patience.
I actually do not know for sure on the exhaust, As I only know about what I've worked on and that is a SOHC.
81 Hardly Davisson
Offline kghost
« Reply #7 on: June 01, 2009, 12:36:24 PM »
I agree with Inks.
Looks like its bent from hanging there.
Massage it back into shape and put a clamp on it.
Stranger in a strange land
rachsrib
« Reply #8 on: June 01, 2009, 04:47:00 PM »
Cool not sure how to massage the exhaust but this is what I did, I loosened the two head pipes and attached the mounting bracket then I wrestled the heads back into the muffler using a thin coat of ultra copper to make them glide a bit better.  Took a few trys at tightening the headers down but it seem to seal up nice.
As a side note in case anyone out there is wondering it seems as though the 77 and 78 cb750k pipes have the same mounting style as the 76 750f. So i think they might be compatible, Can anyone confirm this?
Thanks
