Author Topic: Deep sump Oil pans for CB 750  (Read 13760 times)
Offline BLUE71TURBO
Re: Deep sump Oil pans for CB 750
« Reply #50 on: November 19, 2010, 12:01:40 AM »
 I need one for this.........
Offline voxonda
« Reply #51 on: November 19, 2010, 02:32:22 AM »
DROOLLLLLL!!!!!!!!!!
What carb is that, a SU?
Rob
« Reply #52 on: November 19, 2010, 08:41:48 AM »
Looks like a Skinners Union.. maybe prepped by Rivera Eng....
« Reply #53 on: November 19, 2010, 08:49:35 AM »
 Spanner1, paint is a nonsense fashion item.. strip it off and just clear or plate everything to protect it...
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #54 on: November 19, 2010, 11:14:33 PM »
Just curious..... If you were able to run a deep pan, oil cooler, larger spin on automotive type filter, and do away with the oil tank?  ???
I'm not really wanting to try this, but thought I would ask.
I seen a bike that the Wrench monkee guy's built and they don't have a deep pan or an oil tank.
Must be for show only and no riding....
I just noticed the copper looking oil lines going up under the seat.....
But on this one...... I don't see anything....?
« Last Edit: November 19, 2010, 11:20:50 PM by Brian77cb750 »
Offline lordmember1969
« Reply #55 on: November 20, 2010, 03:00:28 AM »
 The engine is a dry sump type incorporating a separate oil tank which is mounted on the
right side of the frame. The oil in the tank is delivered under pressure by the oil pump
to lubricate the engine components. The oil accumulated in the crankcase sump is returned
to the oil tank by the scavenge pump, however, part of the oil is deverted to lubricate
transmission components.
Here are some more useful information, it basically says that you need the oiltank because the engine is fed directly from the oiltank. The sump is the return and are constantly dry, pushing the oil back to the tank? So a larger sump will increase oilcapacity and quality in the long run but you can not run whitout some kind off oiltank, because the engine is not fed from the sump? This is how I read it ? Am I right???
http://cb750k2.tripod.com/lubrication-system/lubrication-system.html
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
srook
« Reply #56 on: November 20, 2010, 10:27:48 AM »
Yes, you need an external oil tank on the CB750.  There is no limit to the shape or placement of the oil tank though.  The first picture of the Wrenchmonkees bike has the oil tank in the tail of the seat.  The second picture has an oiltank that is probably compartmentalized in the gas tank.  The lines are probably run along frame tubes to hide them.
Scott
Offline BLUE71TURBO
« Reply #57 on: November 20, 2010, 10:54:11 AM »
Rob
  Yes it's a SU carb from RIVERA.  Works great !
« Reply #58 on: November 20, 2010, 11:06:05 AM »
Told ya.. Skinners Union.. and blueturbo.. you are calling that 550 aircleaner small.. :o
 Thought, I had heard,  that renchmonkee bike with flat seat was an empty motor sculpture for a restaurant..
« Reply #59 on: November 20, 2010, 03:15:02 PM »
Yep, apparently the 2nd bike hangs on a wall in a shop somewhere.....what a waste..
Offline BLUE71TURBO
« Reply #60 on: November 20, 2010, 04:59:04 PM »
   This air cleaner is only 3 inches across.......http://www.knfilters.com/search/product.aspx?Prod=RU-2580
    The one in the picture on the air box is way larger.  The air cleaner on mine is 6 inches across.  ;)
Offline jumbulias
« Reply #61 on: September 20, 2016, 03:59:05 AM »
Hello would like to know where you got your deep KZ oil pan  . been looking for a long time . Any help appreciated
