75 CB550 (K1). Stock horn/harness.
Horn sounds loudly when connected directly to the battery at 12.5 volts. Voltage at the horn harness connection points is roughly 11.7 volts when the switch is activated. However, when the horn is connected and the switch depressed, the voltage disappears and no sound can be heard from the horn. Adjusting the contact screw makes no difference.
Any ideas as to why the voltage would go down to zero under load? Bad switch contact or ground, perhaps?
