Author Topic: its charging ok what the heck 900  (Read 3145 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: June 01, 2009, 08:00:57 AM »
Checked the voltages ...wrote the numbers down at home....the charging system seems to be working fine. I cleaned all the coil connections....that didnt help...checked and cleaned up the ground..that didnt help. I need to mess with the rpms it is running pretty fast didnt know if that could make it heat up to much and maybe that is part of the problem. Also I raised the Rpms because it seems to be choke heavy in the beg. even when it is warm out maybe that is pointing toward one of the multiple problems that could be causing the cold start issue.
« Last Edit: June 01, 2009, 08:27:31 AM by cb650 bobber »
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Laminar
  • Retsam
Re: its charging ok what the heck 900
« Reply #1 on: June 01, 2009, 08:40:33 AM »
What's the problem that you're trying to solve?
  • stupid gloripope
« Reply #2 on: June 01, 2009, 08:55:39 AM »
Wont start after initial ride...Taking it that heat is an issue. Will start in about 10-15 min once it has cooled.
« Reply #3 on: June 01, 2009, 09:27:50 AM »
Jeezz, do we have to drag each little detail out of ya?  You make it so hard to help.
Does the engine not spin with the starter or spin with the starter but not fire?
  • stupid gloripope
« Reply #4 on: June 01, 2009, 09:49:18 AM »
SPins just doesnt fire....Sounds like a normal start except it doesnt fire up.
« Reply #5 on: June 01, 2009, 09:54:39 AM »
I recently read in other posts that the pulser coils fail and cause this problem on the 650.
  • stupid gloripope
« Reply #6 on: June 01, 2009, 10:01:03 AM »
what is the pulser coil....just one of the standard coils
  • stupid gloripope
« Reply #7 on: June 01, 2009, 10:10:41 AM »
I am guessing getting new coils would expensive and take a while
  • stupid gloripope
« Reply #8 on: June 01, 2009, 10:17:58 AM »
and also is there upgrades to the standard coils.... I got a used pair last time...mine was cracked and would give my fits when it would rain.
« Reply #9 on: June 01, 2009, 11:07:28 AM »
No, the pulser coils are near the crankshaft.  These tell the spark box/units to fire the high voltage spark coils, when the crankshaft is in the proper position.
If the pulser coils fail with heat, the spark units can't make the main coils fire the spark plugs.  Pulser coils actually trigger the spark units.
You should be able to test for spark when the unit is hot.  If you have spark when cold but not (or weaker) after it gets hot, suspect the pulser coils.
  • stupid gloripope
« Reply #10 on: June 01, 2009, 11:53:17 AM »
where can i get a pulsar coil....should i just call some dealerships and see if they are stocking it.
  • stupid gloripope
« Reply #11 on: June 01, 2009, 12:08:18 PM »
Or should I do some cleanup on the connections maybe or that wouldnt help. Can I test with a volt meter.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #12 on: June 01, 2009, 12:09:25 PM »
That wouldn't help. When they go south, they go south for good.
No.
  • stupid gloripope
« Reply #13 on: June 01, 2009, 12:38:06 PM »
so if it went south for good it could still be ok when cold just not hot.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: June 01, 2009, 12:41:01 PM »
It could exhibit normal operating characteristics while cold. Which doesn't last long in a running motor...
No.
  • stupid gloripope
« Reply #15 on: June 01, 2009, 12:49:36 PM »
would it effect the way it runs then. Because the bike seems to run fine even for rides where the motor is def. hot. It just wont after it gets hot.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #16 on: June 01, 2009, 12:58:12 PM »
Kit went through much of the same. You should read her threads.
No.
  • stupid gloripope
« Reply #17 on: June 01, 2009, 01:07:24 PM »
I have found a lot of threads seems like everyones issues are different ...I am really thinking it may be the pulser coil. Now I have to call the dealer and see how much they want for one.
« Reply #18 on: June 01, 2009, 01:09:42 PM »
You have two pulser coils.  Each one fires a pair of cylinders.  I wouldn't replace anything until I tested it and found it bad.
  • stupid gloripope
« Reply #19 on: June 01, 2009, 01:13:44 PM »
ok how can I test those coils....I am taking it they are in the side cover on the right side of the bike....right side if you are sitting on it that is...
« Reply #20 on: June 01, 2009, 04:18:53 PM »
The pulse coils are under a cover on the right side of the bike, I think.  There should two yellow and two blue wires going there.
 The wire diagram shows these wires going to your spark units.  You can probably disconnect at the spark unit and measure the resistance of the wires and the coils from that location.  Take a cold measurement across the yellow wires, blue wires (disconnected from the spark unit). And then when it's is hot and won't start take another measurement then.  If there is a big change in resistance, you probably found the problem.
I'm assuming you have already checked for spark both when the engine is cold and when the engine is hot.  If there is no spark difference with heat, probably no need to measure the pulse coils.
  • stupid gloripope
« Reply #21 on: June 02, 2009, 05:09:46 AM »
no I havent checked the spark yet everytime I do something I am in a hurry as I watch the baby at night that is why this thread has been such a pain I have to try and find time to do things. SO last friday I cleaned up the coils changed the fuel filter and tried that ...no dice.
  • stupid gloripope
« Reply #22 on: June 02, 2009, 06:43:26 AM »
I will check the spark so I guess if I check it hot and cold and it is good then it isnt the pulser.
  • stupid gloripope
« Reply #23 on: June 03, 2009, 05:31:22 AM »
Well I didnt get to check the spark but took it around the block to see if it showed anyother signs of issues.....it misses when you hammer the throttle as well. Not sure if this would still be an issue that could point to the pulser coil
