Why would Keyster needles not work? They can't be so different that they can't be adjusted to work right. All 4 pipes do get hot. At first they didn't. I cleaned the carbs again and got all four cyinders burning.
Setting valve clearances would involve finding special feeler gauges that would fit into tappet hole and getting a tappet tool or finding something that would work. How would valve clearance change from sitting? Better yet, how would valve clearance ever change? Same valves, same engine. It doesn't seem like the clearance would change on it's own. Could valve clearance problems really cause what I am observing?
Honest questions here. Not being a jerk. Thanks for the help.
I'm just recommending that you might check the needles, here's why:
The Keyster needles in the 500/550/750 carbs have a real bad track record of being the wrong tapers. Some SOHC4 users have even reported getting different tapers and differing lengths with the same part numbers when buying sets of 4 for these bikes. I've even seen pix here at SOHC4 of the same story with their fuel valves and seats, in a set of four.
I just finished a month-long e-mail troubleshoot with one of our members on a 550, trying to rectify a real severe stumble at about the same RPM range you're fighting: I completely forgot to ask him to check for Keyster needles. After trying every adjustment possible, to no great success, he discovered they were Keyster and bought Honda: problem solved in two hours. Search the forums for Keyster and you'll find lots of similar examples. They may work on other carbs, but have a poor history on the SOHC4 sets.
I don't wish to be "down" on any particular parts builder, if they are trying to make stuff for our toys. But, I don't know anyone at Keyster, or else I would pursue the fix with them, as an Engineer. I've done this already with a couple of our non-Honda 'suppliers', and they have been eager to fix the problems: very promising for our future! So, if anyone who reads this thread does have a clue to a Keyster contact, please forward to me?
