Author Topic: Bike won't go Backwards  (Read 1839 times)
Offline turkey4me
  • The closer you are the less you can see!
« on: June 03, 2009, 06:51:28 am »
Just about finished rebuilding a 76 Honda CB 750 F.  With the bike clearly in neutral I can roll forwards with ease but can only go backwards about 2 feet then she binds up somewhere and stops.  Even with the clutch lever compressed same deal.  Any ideas!  Doesn't appear to be the rear wheel.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Bike won't go Backwards
« Reply #1 on: June 03, 2009, 06:54:57 am »
When you say it doesn't seem to be the rear wheel, does that mean you have put it on the center stand and tried spinning the rear wheel in reverse and all is OK?
« Last Edit: June 03, 2009, 07:55:57 am by Bob Wessner »
Offline turkey4me
« Reply #2 on: June 03, 2009, 07:54:35 am »
No centerstand otherwise I would have tried turning just the rear wheel.  I will put her up on blocks tonite and see what happens.  Frustrating to have been on this project for 6 months and now i can't get out of the garage!  Hopefully it is just the brake binding and not another issue.
Offline tlbranth
« Reply #3 on: June 03, 2009, 08:02:12 am »
Bunged up speedometer drive?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #4 on: June 03, 2009, 08:25:19 am »
Chai hanging up on kickstand?
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #5 on: June 03, 2009, 12:59:43 pm »
Caliper might need adjusted.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline turkey4me
« Reply #6 on: June 03, 2009, 06:04:35 pm »
I knew it was something retarded.  How about a 6 mm nut sitting quietly on the chain!  That would certainly stop a bike from going backwards!
MrHellpop
« Reply #7 on: June 03, 2009, 07:23:29 pm »
Those nuts like to do that. Happened to me once. I thought I totally 'busted' the transmission until I noticed that sucker! ha ha ha
Offline tlbranth
« Reply #8 on: June 03, 2009, 07:49:35 pm »
That was my next guess.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #9 on: June 03, 2009, 09:40:03 pm »
Did it wheel backwad and forward before you did your rebuild and how much of a rebuild did you do?
Sam. ;)
Offline crazypj
  • I'm brill, me
« Reply #10 on: June 03, 2009, 09:45:31 pm »
I've seen it happen when kickstart gears/return spring isn't correctly assembled
PJ
« Reply #11 on: June 03, 2009, 09:50:23 pm »
That's what I was thinking.
Sam. ;)
Offline crazypj
  • I'm brill, me
« Reply #12 on: June 03, 2009, 09:54:22 pm »
Damn Sam, your up early  ;D
PJ
Offline Alan F.
« Reply #13 on: June 04, 2009, 06:51:27 am »
That nut was a spare, right?  It's not missing from someplace important?
« Reply #14 on: June 04, 2009, 12:13:28 pm »
PJ
« Reply #12 on: Today at 12:54:22 am »  that's 5:54:22 am in the UK and I was about finish work and go home to bed.
No, I was up late. :D :D :D :D
Sam. ;)
Offline crazypj
  • I'm brill, me
« Reply #15 on: June 04, 2009, 11:40:05 pm »
PJ
Sam. ;)
 ;D
I knew that, its why I mentioned it. (I ain't from round these parts ;))
 My brother used to think it was funny calling 7.00am British time
PJ
