271.00 from honda dealer ouch
Not bad considering the alternative I went with...
I am running a dyna2000 setup.
with the kit, and programming kit(not really needed, but nice) 400+
Surprisingly I used a DOHC cb750 kit.
The downside is I had to graft the dyna2000 pickups (triggers?) onto the stock timing plate.
AS WELL as modifying the crank trigger to have the locating pin on the correct bolt circle as well as the correct diameter.
If I was not a machinist, I guess the damage would have been 600+.
Luckily I had all the tools/machines and materials to do the needed work at the time.
Have you tried running without your air filter in??
If it runs better, mabey you just need a new filter.
l8r
