Author Topic: Score! **750 cafe build** Completed!  (Read 37822 times)
Offline Speed King
Re: Score! **750 cafe build**
« Reply #50 on: August 24, 2010, 10:16:15 AM »
Damn, Dude that thing is looking good! Can't wait to see more.
Offline tweakin
  • tear down
« Reply #51 on: August 24, 2010, 08:26:37 PM »
Man, the build is looking great.  Keep it up.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #52 on: August 24, 2010, 10:25:59 PM »
looking sick!
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline Shoeboxjoe
  • Large Breasts
« Reply #53 on: September 03, 2010, 07:25:57 PM »
Finally got oil pressure after pulling the gauge out and pouring oil in the hole where it mounts. Picked up an electronic relay for the blinkers and buttoned up all the wiring. Got a one piece stainless steal braided brake line from http://slingshot-cycles.com
Had to trim the seat up a bit to make it fit better with the new seat pad and then had a friend paint the tank and seat...
Ran all the fuel lines and installed the headlight with new chrome ring, tank and seat, new decal...
It needs more decals or pin stripes or something, still not sure what to add yet. Right after taking this pic i put a gallon of gas in and was about to see if it fires when the petcock started leaking gas like mad in the off position! So had to stuff a rag around there and pull the seat and tank back off. It was leaking from one of the barbed copper tubes, bad o ring or washer maybe in the petcock?? I ordered a rebuild kit but it probably won't be here until the middle of next week!! I was hoping to spend the holiday weekend tuning and working the bugs out!  >:( I guess i can spend the weekend drinking beer since there will be no riding.
Still waiting for gauges and air filters which should also be here next week! Could use a shorter clutch cable also  :P
I'm hoping to get it running well enough to take it to up north Tomahawk WI for the annual Fall Ride in 2 weeks, even though it's mostly a Harley rally. Hope to be updating this thread soon with video of the bike running.
« Last Edit: October 04, 2010, 01:53:10 PM by Shoeboxjoe »
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
Offline Shoeboxjoe
  • Large Breasts
« Reply #54 on: September 04, 2010, 10:47:56 AM »
Got some fiber washers for the petcock from Ace hardware and that fixed the leak so it looks like i have to stop drinking and see if i can make this bastard fire! The 1/4" fuel line leaks around the barbed tubes from the petcock so i had to add some hose clamps. Also a little leak from the bowl even with a new o ring, perhaps just tighten that up a bit more. It was just starting to pop when the battery went dead!! So got the battery on the charger now and shut the fuel back off. Hopefully i'll have it running today.
Offline Shoeboxjoe
  • Large Breasts
« Reply #55 on: September 04, 2010, 04:38:29 PM »
Got it running this morning, here's a bad phone video of it starting...
Aside from the broken clutch cable and some small oil leaks, there's only one lingering issue that i haven't figured out yet. After riding about 15 minutes or so when the bike gets up to a good temp, it starts running like #$%*. Seems to lose power when you're on the throttle and stumbles and sputters but it idles ok for a bit and eventually gets worse and worse until it dies. At first i thought i was running out of fuel but i had plenty. When i let it sit for 5-10 minutes it starts and runs fine again until it gets hot. Any ideas what it could be? Right now i have no air filters (pod filters ordered) and a totally open exhaust. I replaced the jets with new stock ones from a rebuild kit, do i need larger jets? Would improper jetting cause it to stumble at a hotter temp but run fine when its cool? Any input would be appreciated but in the mean time i'll start digging through the forum for answers.
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #56 on: September 06, 2010, 05:50:40 PM »
I love that white and red on the blacked out frame and bits. Seriously cool looking and the exhaust sounds great too. Great job!
Rick
1995 EG6
Offline Shoeboxjoe
  • Large Breasts
« Reply #57 on: September 07, 2010, 07:14:39 AM »
With help from another post on this forum, i think i've found the cause of the bike running like #$%* when it's hot. Someone suggested vacuum lock in the gas tank and i noticed there's no vent in the gas cap on the tank. so i drilled two 1/8" holes in the spring plate under the gas cap to allow venting. After doing this I fired the bike back up and noticed fuel everywhere under the tank. Apparently the cheap Ace Hardware 1/4" fuel lines don't deal with heat very well, they were very soft and now leaking at the in line fuel filter connections which is probably the real cause of the bike running like #$%*.
Also I've noticed the fuel tank is weeping fuel from one small spot along the seam. It seemed to be getting worse through out the day so I drained all fuel and aired the tank out. I'm waiting for some Caswell's Epoxy tank sealant at the moment and was going to try resealing the tank. Gauges and air filters should be here this week. I'm still hoping to have the bike ready for the Tomahawk Fall Ride on the 17th.
Thanks for the comments! I appreciate any feedback :)
Offline fastbroshi
  • Puppet
« Reply #58 on: September 07, 2010, 07:25:41 AM »
That's a damn good video for a phone!  You should see the pics, let alone the vid my phone takes.  My phone is a Commodore 64 compared to your super computer phone.
Just call me Timmaaaaay!!!
Offline HedNut
  • Underwater Basket Weaving
« Reply #59 on: September 07, 2010, 08:42:27 AM »
Wow DUDE!  I wish I would've seen this build come together! GREAT STUFF!!  At least I'm here for the good parts!  Love the look of your bike!!!
Cheers!
Offline Shoeboxjoe
  • Large Breasts
« Reply #60 on: September 15, 2010, 09:29:01 AM »
Resealed the gas tank with Caswell's Epoxy (great stuff!), installed gauges, mirrors, air filters, rebuilt petcock, new fuel injector hose for the fuel line and removed the leaky inline filters. Filled the tank last night and the exterior is still dry as a bone today so hopefully we're good to go! Registered the bike this morning so I'm legal now. If the weather dries up I'll take it out this evening and see if the bugs are ironed out.
Tach only goes to 8k but i got a deal on it :P
If anyone's interested I found that ordering the K&N filters individually was cheaper than ordering the set of 4. These were part number RC-0160 which are .5" longer and don't taper but I like the look.
Made a steel plate side cover that doesn't stick out as much as the OEM plastic ones.
« Last Edit: October 13, 2010, 05:22:20 AM by Shoeboxjoe »
Offline Shoeboxjoe
  • Large Breasts
« Reply #61 on: October 01, 2010, 08:11:14 AM »
Put about 250 miles on since the rebuild. Recently put in 130 main jets and adjusted the needles as much as possible to give it more fuel. It runs good but at 50mph or more it doesn't like to maintain a speed even though it accelerates great. It will maintain a speed but you can hear it stumble slightly as if it were running out of fuel. It's much better than it was with the needles adjusted and new jets but still feels like it's wanting more fuel while cruising at like 1/4 to 1/2 throttle, but only while doing 50mph or more.
Added some pin stripe decals to the top of the tank and seat, bar end mirrors, and a new clutch cable.
Also added some HM wing decals to the oil tank and the side cover.
Made a steel plate side cover, it ended up a little crooked when bolted on but im happy with it.
Think I'm calling it DONE! Or done until I can afford one of the CycleX "Git Kits"  ;D
« Last Edit: October 01, 2010, 08:18:54 AM by Shoeboxjoe »
Offline domer
Re: Score! **750 cafe build** Completed!
« Reply #62 on: October 01, 2010, 08:50:01 AM »
god damn thats pretty! now on to the chopper!!!
Offline brandEn
« Reply #63 on: October 01, 2010, 08:59:04 AM »
WOW, looks friggin great. I really like the white with red seat. I can only imagine how good it feels to be "done." Good job!
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #64 on: October 01, 2010, 11:12:11 AM »
Congrats, on a job well done!
1995 EG6
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #65 on: October 01, 2010, 06:17:54 PM »
Very nice bike, man!!
I'm wanting to paint my bike white also with the black rims.
Offline HedNut
« Reply #66 on: October 04, 2010, 06:28:39 AM »
Stand up job SBJOE!!! Wow...I absolutely LOVE that tank/seat combo..and you done it wicked with the white paint/red seat!  Very clean looking bike!  One slik ride!  Cool and congrats on getting it "done".   (We can never REALLY be done...here's always something on the wish list...hehe)
Cheers!!
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #67 on: October 06, 2010, 11:33:25 AM »
Can I have the orange fairing and bags?
333:  Think "Shakeweight".
Offline MorePDX
  • the project, '77 750K
« Reply #68 on: October 09, 2010, 01:41:38 AM »
Nice build, thanks for sharing!
If it ain't broke, don't fix it!  -my dad
Offline Shoeboxjoe
  • Large Breasts
« Reply #69 on: October 13, 2010, 05:26:45 AM »
Sorry sold the bags. No one seems to want the fairing. The windscreen is severely cracked, the wiring is pretty cobbled and there's holes cut in the fairing for a radio or CB or something.
Offline Shoeboxjoe
  • Large Breasts
« Reply #70 on: May 16, 2013, 04:16:50 PM »
Sold this bike earlier this spring, now that the weather is nice I'm kicking myself!
This cafe build was a great learning experience for me, and i really appreciated all the positive comments! I think the next one we can do bigger, stronger, faster, and hopefully cheaper!
Anyway, picked up a '77 cb750k that will be the future project.
« Last Edit: May 17, 2013, 06:04:06 AM by Shoeboxjoe »
Offline Ricky_Racer
« Reply #71 on: May 16, 2013, 05:11:07 PM »
Nice clean job. I like the red upholstery with white. Very dramatic.
Ahem...  Ahem...  And I really like the wonderful, tasteful, detailed HM Logo and CB750 stickers.  I think everybody should have at least one set, especially since they come in five great colors including chrome!  ;) 8) ;D RR
Offline davis96
« Reply #72 on: May 16, 2013, 06:25:32 PM »
A few things:
1) I LOVE build threads like this. You know exactly what you want to build, no funny business, no time wasting and quick progress. Also, the bike is a beaut!
2) I'm just sayin', a couple red decals and you could recreate this design. Some love it, some hate it, but the more I look at it the more I dig it:
Would look super cool.
Keep up the good work
Davis
'74 CB350F - sold
'71 CB500K
Offline Bankerdanny
  • Endeavor to persevere
« Reply #73 on: May 17, 2013, 02:49:29 PM »
Looks fast, but I'm not sure that those bicycle disks on the front are up to the task of stopping it. Plus that downward angle won't do any favors for fuel flow.
Seems like more of a trailer to the show than get up and go bike.
It is pretty though.
« Reply #74 on: May 17, 2013, 07:40:43 PM »
Nice inspiration, but I have to agree about the practicality of those brakes and the mounting angle of the tank.
