Author Topic: cb400f oil screen filter  (Read 1000 times)
Offline reed
« on: June 04, 2009, 02:07:24 PM »
i removed the oil pan to fix some drain plug issues. i am told that it is a good idea to clean the oil screen filter while i have the pan off.
what would you guys recomend i use to clean this part?
thanks.
Offline jeepster
Re: cb400f oil screen filter
« Reply #1 on: June 04, 2009, 04:03:46 PM »
This is also on my list... Clymer just says "solvent". Maybe engine degreaser?
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline Bodi
« Reply #2 on: June 04, 2009, 06:48:10 PM »
A stiff brush and a pan of varsol does the job nicely. If you want it to be super clean, use spray-9 after the varsol.
