Author Topic: cam sprocket!  (Read 604 times)
Offline pinnacle
cam sprocket!
« on: June 04, 2009, 11:20:38 pm »
i am assembling my motor again and have gotten to the head and installation of the cam and sprocket.shop manual says to set your timing mark on the 1-4 t mark and have the notch on the cam be in the middle.mine is just a tiny bit off is it posible to be one tooth out on the sprocket and should i remove and redo or can you get away with being one tooth out?
1974 cb550, 1978 cb550, 1984 honda shadow vt750
Re: cam sprocket!
« Reply #1 on: June 04, 2009, 11:38:53 pm »
One tooth out is too much, it may not be exact but needs to be less than a tooth
Offline MIKE550/4
Re: cam sprocket!
« Reply #2 on: June 04, 2009, 11:41:34 pm »
i did mine recently ( top end rebuild )
put on t mark 1-4 ( exactly ) the flat of the cylinder head should be in the middle of the notch on the cam , a pain but get it right while your there , also read up on cam cover replacement,
a certain bryan j advised me as well  :D
cheers mike
