Author Topic: Regulator / Rectifier build ?  (Read 14820 times)
Offline Paul
« on: April 18, 2005, 08:58:49 AM »
This is actually for a friends Ducati, but I'm sure the principal is the same.
OK. so how does one make a regulator / rectifier combined. I've already installed a new bridge rectifier with heat sink on my CB500 but the regulator was ok so no need to go there. Now....instead of paying £120 ish for a combined unit I want to make one (as part of a learning excersise aswell.) So I've got the heat sink £6.00 and the rectifier £5.00 and I think I need to wire up a zener diode to restrict the DC output from the rectifier down to 14V ish, but thats as far as I know...........so ....who's up for it? (oh ya ..and if one could limit the components to actual component descriptions as opposed to "Radio Shack" parts as ....we don't have them over here. but we do have Newark, Radionics, Farnell etc).. Awaiting your replies with enthusiasm.
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Regulator / Rectifier build ?
« Reply #1 on: April 18, 2005, 09:49:44 AM »
Frank Cooper built loads of stuff for his 500/4.
Check his site:  http://homepage.ntlworld.com/frank.cooper1/frameset.html
He describes how he built a rectifier and electronic regulator
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
sniknuoy49
« Reply #2 on: May 17, 2005, 06:34:15 PM »
how can i get hold of him
sniknuoy49
« Reply #3 on: May 17, 2005, 06:55:51 PM »
need to know  what the watts are on the resistors  and the select on test switch  and a part no. on the led.
a part description  and no. for 5v1    need to know how many watts, volts and ohms on all the caponents.
     i will be very thank full   please help
    • TVAM
« Reply #4 on: May 18, 2005, 01:24:50 AM »
I've never met the guy! He lives in the same town and we passed on the road one morning, did a double take (as you do when another sohc4 passes on the other side) and "met" on the old site.
I've only ever emailed him and will dig out his address when I get home later.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Raul CB750K1
« Reply #5 on: May 18, 2005, 03:04:00 AM »
How much does a new regulator or rectifier cost? I'm electronic engineer for a living and I could be making money with this. For a rectifier you need 6 high power diodes and a heat sink. For a regulator, a high power transistor, a heat sink, a zener, a resistor and an electrolytic capacitor.
A zener diode, when applied reverse voltage, will set the leads voltage to the preset voltage. The remaining will be dissipated as heat, so the zener needs a heat sink and will always work under stress. Triumph motorcycles used to have the rectifier under the headlight.
Now put a resistor in series with the zener. The zener will still set the voltage across its leads, but the resistor will eat the remaining voltage. There is no need for a heat sink. Apply the voltage to a high power transistor in emitter-follower configuration. It's ouput will "follow" the voltage in its base. The transistor is built to undergo high current and temperature, so it will last longer and will be safer. And everything will be solid state.
Raul
sniknuoy49
« Reply #6 on: May 20, 2005, 04:07:47 AM »
can you tell me how much watts you would use  on that schrematics about . i have most everything not sure of how big to use i need to know watts ohms and volts  all help is welcomed
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #7 on: May 22, 2005, 05:12:00 PM »
I am planning to make this electronic regulator.  The entire system up to the power transistor which controls the stator coil current is very low power.  Half watt resistors should be more than sufficient.  The zener diode can also be low power.  I think almost any 5.1 volt device would be fine.  Selection of the S.O.T. resistor (R10) may be best done with a trimmer variable resistor.  I think a 100K ohm device would be adequate.  My intention is to put a trimmer pot of 1K ohms in series with a 1k ohm resistor as a substitute for R8 and R10 in the design of Mr. Cooper.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline jbailey
« Reply #8 on: May 22, 2005, 07:50:01 PM »
I installed an electronic voltage regulator on my 75 550.  It is working great.  I get a steady 14.2 volts now from about 1800 RPM up.  The old VR was all over the place.
What I did was to use a KEM KVR502 that I got from JC Whitney for $10.  It is originally for a 1976 Porsche 911 and fits many other cars of the era.  There are three wires which connect directly to the three from the old VR, however the colors are different.  I can look and see the colors if you are interested.  You can also buy the part locally from Autozone for $29.  It is a Wells VR650.  Same part, different manufacturer.  I got it from Whitney because I was ordering other stuff and it was way cheaper than from a local vendor.  Actually, if you order the part and pay the shipping it is still cheaper than local.
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #9 on: May 22, 2005, 08:46:10 PM »
This sounds good, if you get time could you take some photos and show us what you did. These old electronics are scarey on the road.
Terry
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline Dennis
« Reply #10 on: May 22, 2005, 10:14:37 PM »
Raul,
I was able to follow along for most of your description of the electronic voltage regulator but you lost me on the last part quoted above. This sounds like just the sort of regulator that I need for my Yamaha RZ, which I think you know as the RD350YPVS, with a permanent magnet alternator.
It sounds pretty straight forward. Any chance that you could sketch this circuit for those of us who would like to try to build one?
If you would prefer to send it direct, my address is: DScia@aol.com
Thanks, Dennis
« Reply #11 on: May 23, 2005, 02:51:54 AM »
Dennis, go to my webpage in  http://perso.wanadoo.es/camelo4/indexeng.html.
It's a trip computer, but in the schematic, in the upper left corner, you will see the voltage stabilizer section (with a BD140 transistor). You will have to jack up that transistor to withstand higher currents, using it to drive a high power transistor like a 2n3055 or similar in a Darlington configuration, but the basics are the same. Output voltage is always zener voltage + 0.6 volts of the base-emitter union. The transistor acts like an automatic variable resistor, eating up the difference in voltage. You need that the maximum collector-emitter voltage will be high enough, but there is no problem to eat up 4 or 5 volts.
More questions just post again or send me a PM.
Regards
Raul
« Last Edit: October 16, 2013, 05:37:08 AM by Glenn Stauffer »
Offline dusterdude
« Reply #12 on: May 23, 2005, 05:40:05 AM »
ok this is interesting,i wonder the difference between the honda alternator and the harley style alternator,you see see h-d doesnt use the external style rectifier and im wondering if they use one at all.any ideas?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Dennis
« Reply #13 on: May 23, 2005, 04:00:23 PM »
I don't know how HD builds their alternators so I can't comment on that. All I can say is that if it is really an alternator which I would suspect that it is, there MUST be some rectifiers somewhere.
Just remember that most cars have a diode bridge (rectifier) inside the alternator case. Possibly HD does the same??
sniknuoy49
« Reply #14 on: May 23, 2005, 04:18:59 PM »
  jbailey      could you tell me how you wired it up  or a drawing  thank you
Offline Dennis
« Reply #15 on: May 23, 2005, 08:13:19 PM »
Raul,
Thanks for the link. I tried to look at your page.
"pagina no encontrada"
Mira en el buscador, a ver si así la encuentras.
So, where is it hiding?
« Reply #16 on: May 24, 2005, 12:51:48 AM »
Oooops, they did it again!!! It's a free web hosting service, but as soon as trafic grows they just shut down the space!!!  I'll host it again and will let you know.
Raul
« Reply #17 on: May 24, 2005, 01:42:50 AM »
Offline mgilvary
« Reply #18 on: May 24, 2005, 08:18:55 AM »
Jbailey,
Have you got a JC Whitney part number? I searched their site, but came up empty handed. Alternatively, could you post a link?
And also, I'd love to hear how you connected it. I have a 75 550 as well, and though I've cleaned and adjusted my old VR, I can't get more than 12.5 - 13 volts out of it.
Thanks.
Offline Dennis
« Reply #19 on: May 24, 2005, 10:34:44 PM »
Raul.
Got the schematic this time. I'll draw it, select some components and send it to you before I start to build it. Thanks.
Offline jbailey
« Reply #20 on: May 25, 2005, 11:25:52 AM »
The JC Whitney Part Number is KVR502.  To find it click on "replacement parts" in the left column.  Then search for a 1976 Porsche 911S voltage regulator.  Or go to your local parts store and ask for a voltage regulator for a 1976 Porsche 911S.
I've attached a picture of the Voltage regulator and one of it installed.
Wiring is:   VR          Honda
             Black         White
             Brown       Green
             Blue          Black
I had tomove things around slightly as you will see in the picture, but you will end up with an electronic voltage regulator for about $10-30 and it can easily be replaced at any auto parts store.  If you build your own, good luck repairing it on the side of the road.
« Last Edit: June 25, 2007, 06:48:27 AM by Glenn Stauffer »
1975 Honda CB550K
Offline mgilvary
« Reply #21 on: May 25, 2005, 11:55:02 AM »
jbailey:
Thanks for posting that. I just ordered the VR and am looking forward to being able to ride with my headlight on.
Offline jbailey
« Reply #22 on: May 25, 2005, 12:29:52 PM »
If you still can't get the full voltage, you may have a bad rectifier.  In that case it will do no harm to have the electronic voltage regulator installed, but will need to repair or replace the rectfier.  This should be easy to repair or build since it is just six high current diodes.
If you have a problem with the rectifier, let me know.  I could probably build you one for a few bucks if you don't want to try it yourself.
1975 Honda CB550K
« Reply #23 on: May 25, 2005, 03:14:31 PM »
Being an electronic engineer as I am, if it's 10-30$ I would buy it instead of making one. I rather spend the time riding than tinkering...
Raul
Offline mgilvary
« Reply #24 on: May 25, 2005, 04:29:04 PM »
You're very kind, sir. I'll plug in the VR when it arrives in a week or so and report back.
