Author Topic: Aluminum rim fix ?  (Read 1046 times)
Aluminum rim fix ?
« on: June 06, 2009, 11:21:10 PM »
Hi Guys, been up north to my property for a couple of days and brought some bike bits back with me. What i want to know is, i have a really nice 3.5 inch DID aluminum rim that came off a drag bike and it has 6 holes either side of the rim where the slick tyre was screwed to the rim. I know i can still use the rim as it is but i want to fill the little holes up. Does anyone know the best way to go about this?
Thanks in advance...
Offline aussie
Re: Aluminum rim fix ?
« Reply #1 on: June 06, 2009, 11:27:57 PM »
Howdy mick, the holes can be ally welded then filed flat, if your lucky you may get no distortion. If you do ,you can get the rims re-rolled .
Have you thought about just getting some small alloy plugs machined up, maybe taping a thread in the rim then screw the plugs in with some loctite
« Last Edit: June 06, 2009, 11:30:32 PM by aussie »
« Reply #2 on: June 06, 2009, 11:33:38 PM »
Hi Aussie, i would rather have them filled, i was thinking of something like devcon but was a little worried about the holes ending up a different colour. They are beautiful rims and i want to use them on my F1 cafe bitza... ;D
Offline aussie
« Reply #3 on: June 06, 2009, 11:38:10 PM »
Come to think of it, i was at Quinns marine ( boat shop) the other day and noticed they have alloy repair in a tube. Its like that (need it) that has two parts you squeeze together and makes a putty.
The alloy stuff, can be sanded/filled/drilled and looks exactly like alloy.Its used for tinnys and alloy fuel tanks
« Last Edit: June 06, 2009, 11:39:57 PM by aussie »
« Reply #4 on: June 07, 2009, 01:43:34 AM »
Thanks mate, if you get the chance grab the name of that product and i'll look it up..
Offline Jim F
  • go baby go
« Reply #5 on: June 07, 2009, 04:20:22 AM »
I have welded my rim that was off a drag bike and it works great
I will send pictures if needed
call me at 770-367-7320 for any questions or e-mail at jmfmicroweld@earthlink.net
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #6 on: June 07, 2009, 04:43:12 AM »
tig the holes up and just machine the welds flat again, no worries
Mark Twain - Notebook, 1894
« Reply #7 on: June 07, 2009, 05:01:58 AM »
Thanks for the replies guys..
Offline Alan F.
« Reply #8 on: June 07, 2009, 07:43:44 AM »
Here's my recommendation, check out the videos and read the specs, it's good stuff. Lower temps too, so it might not cause any warpage. I've used it for repairs and fabrication, so I think I can honestly recommend it. A's a side note, small quantities are available on eBay from several sellers.
www.aluminumrepair.com
