Author Topic: How do I remove my starter?  (Read 1888 times)
clemsparks
« on: June 07, 2009, 07:09:30 AM »
Hi all,
I have searched, but don't see any specifics after several pages of results for "remove starter."
Anyway...'74 CB750.  I've got my starter cover off and the starter is loose.  I've moved it back in it's spot but cannot get it to come out.  Do I need to remove the alternator cover and remove teh gear?
Can someone walk me through the proceedure of removing the starter?  I think I'm missing something OR just being cautious as I don't want to screw something up due to the fact that I'm unfamiliar and inexperienced with the bike.
I genuinely appreciate your help,
Clem
Offline Johnie
Re: How do I remove my starter?
« Reply #1 on: June 07, 2009, 07:55:13 AM »
Try this: http://forums.sohc4.net/index.php?topic=38874.0
I also found some other tips if you do a search of "starter removal" on the board.
« Last Edit: June 07, 2009, 07:59:00 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Frankenkit
  • Industrial Strength
« Reply #2 on: June 07, 2009, 07:56:04 AM »
I'm not sure if your setup is the same as mine, but mine's a 650.  To remove my starter, I take off the starter cover, then the left engine side cover- the cover over the oil pump and front sprocket.  There you'll see (if the 750 is the same as the 650 in that respect) wire routing for the stator, but also wire routing going to your starter.  There are a couple bolts holding the starter in, those come out, then you should be able to pull the starter straight out toward you.
Hope that helps.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
clemsparks
« Reply #3 on: June 07, 2009, 11:38:55 AM »
Thank you and the person who posted that tip very much!
And thanks for the patience with a new guy...I'm not sure how I didn't find that...but I tried.
Thanks again all!
Clem
Offline Johnie
« Reply #4 on: June 07, 2009, 12:31:30 PM »
Welcome to the boards...we like pics, we like pics, we like pics!!!  ;D
Oshkosh, WI  USA
Offline myhondas
  • Not really such a
« Reply #5 on: June 07, 2009, 06:29:32 PM »
Welcome to the forum.... you might also want to go to the manuals download area and get the pdf's if you don't have the shop manuals.  Great bike the K4....enjoy it.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
