Author Topic: static vs dynamic  (Read 1225 times)
Offline Burnboy
static vs dynamic
« on: June 07, 2009, 08:18:05 PM »
Im kinda of a newbie on timing. Ive read all I can and thin I have it down but still have a few questions that I need confirmed. Dynamic timing involves a timing light and is done with he engine running, Static timing is done with the engine off right? When I had the top end off of my 750 I aligned everything up so that When I turn the crankshaft  the number one plug fires right as the indicator mark is on the 1.4 line and the same for 2.3 and plug #2. This means Im timed right?  What are the advantages of dynamic timing, ive read that it is more accurate but I dont see how. Thanks in advance.
1975 CB750
1973 CB350F
Offline myhondas
  • Not really such a
Re: static vs dynamic
« Reply #1 on: June 07, 2009, 09:06:44 PM »
Static is a good starting place. I have even used a matchbook cover to set the point gap in static mode. But you can't beat dynamic. A good tach, dwell, timing light and you can get your dwell on the two within a few tenths of a degree of one another. then with the engine running, you can get the timing right dead on, including the advance.  Yea.... you will want to do a dynamic check.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
« Reply #2 on: June 07, 2009, 10:26:30 PM »
I used to do both static a dynamic with the timing.  Now I don't race the bike anymore and static timing is more than adequate.  You do need the timing light to check the advancer function.  But, I haven't noticed any difference in engine power on the street with either a static or dynamic timing performed.
I mostly run the 550's, FYI.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: June 08, 2009, 06:48:27 AM »
As LLoyd says, if the advancer is working correctly, static timing almost always gives proper dynamic timing, assuming your points are in good repair.
No.
