Author Topic: Do I have a bent center stand or some other problem?  (Read 2246 times)
Offline Damfino
« on: June 08, 2009, 12:24:56 PM »
When my bike is on the center stand it seems to lean to the starboard side. (when looking from the back it leans to the right)
Do I have a bent center stand or could it be something else?
Here are pics:
BTW: Sidestand is extended but not touching ground, just fyi.
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Johnny5
    • CB350F build thread
Re: Do I have a bent center stand or some other problem?
« Reply #1 on: June 08, 2009, 12:55:02 PM »
Does it track poorly? Do you feel it pull to one side or the other?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: June 08, 2009, 01:17:45 PM »
i'd swear it almost looks like the frame has a slight counter-clockwise twist. of course i might be imagining things too. lemme ask my imaginary friend freddy what he thinks.  ;D
Mark Twain - Notebook, 1894
Offline Damfino
« Reply #3 on: June 08, 2009, 01:19:11 PM »
Not really that I notice. But then again I've only put about 150 miles on it since buying it last fall and really haven't ridden since I was a sophomore (1981) in high school. Maybe I'm chalking up bad behavior on the bikes part to my lack of riding skills?
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Damfino
« Reply #4 on: June 08, 2009, 01:22:00 PM »
Freddy? Or did you really mean Fuzzy? ;) ;) ;)
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« Reply #5 on: June 08, 2009, 01:27:26 PM »
I have never really examined it, but aren't the feet on the center stand tubes?  Maybe one of them is crushed a bit and changing the foot height?
Offline Mdub
  • Xspurt
« Reply #6 on: June 08, 2009, 01:35:44 PM »
Wierd, the front end looks vertical while the rear end leans.
If you look down the longitudinal centerline from underneath, do the front and rear wheels line up?
And are they parallel to one another?
I see more engine on one side than the other from the front.
It looks like your neck tube is tweeked to the side?
Measure your center stand shaft at each end to some horizontal feature above or below the shaft
and see if it is "square to the world" (that the dimension is the same, at each end, indicating squareness)
Sure looks like something is tweeked pretty good.
X= an unknown quantity
Spurt= a drip under pressure!
Offline Mdub
  • Xspurt
« Reply #7 on: June 08, 2009, 01:36:57 PM »
Good call Tiny, didn't think of that.
Looks like there's more going on than the center stand though...
Offline tinyrobot
    • ChiVinMoto
« Reply #8 on: June 08, 2009, 01:52:53 PM »
plus not to point out the pink elephant or anything, but have you set it on level ground to start with???   ;)
Offline Damfino
« Reply #9 on: June 08, 2009, 01:53:37 PM »
Here is a link to a photo album where you can view the pictures in full screen....
http://picasaweb.google.com/Schmthaus/MyCB750K6CenterStandIssue03?feat=directlink
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Damfino
« Reply #10 on: June 08, 2009, 01:55:08 PM »
Yes to that. ;) The lean is noticeable wherever I park it.
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Damfino
« Reply #11 on: June 08, 2009, 02:02:54 PM »
I should also add that even though the bike shows signs of being dropped on both sides, (minor scuffing to turn signals, mirror arms, points cover, etc.) the frame itself shows no signs of outright damage and most of the bolts on the bike still have the factory yellow markings.
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Hush
« Reply #12 on: June 08, 2009, 03:01:26 PM »
The centre stand looks to be too narrow, maybe it got squashed at some stage in a drop, if I was going to do anything it would be to drop the centre stand off and get it measured as this is the cheapest of all options.
If it;s a frame twist then you are in big trouble.
Oh yeah and check out the second photo, does he need a rear wheel alignment, looks a bit too much to the left or is that optical illusion?
Offline Johnie
« Reply #13 on: June 08, 2009, 03:05:42 PM »
I had the same problem with my KO when I first got it.  Turned out the center stand had 1 leg spread out.  I think the PO did that to accomodate an aftermarket 4 into 2 exhaust.  I found a used one on eBay, primed and painted it and it sits good now.  Take a measurement between the lower legs of the stand and post it.  Then someone with that bike can measure his and let you know if there is a difference.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #14 on: June 08, 2009, 06:09:47 PM »
I gotta 2nd this. It looks like the the motor is over a bit, but maybe the front end is turned slightly so it could be an illusion? But the rear wheel definantly looks off. Are the adjusters set at the same distance on the swing arm? Thats a really nice bike & would really suck if the frame is tweeked.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline JS550
  • IAFF local 1307
« Reply #15 on: June 08, 2009, 06:11:01 PM »
Also when you look at the pic of the rear, the shocks look like they lean in the same direction?
Offline smccloud
    • Shaun's blog
« Reply #16 on: June 08, 2009, 06:25:34 PM »
My K2 leans the same way (and almost the same amount) but I have never noticed any handling problems and it had factory exhaust when I got it.  I just thought they all did that  ??? ??? ??? ???
CB750 K2
Quote from: Hush
Who needs a mobility scooter when you've got a SOHC4?
Gun/Cars/Motorcycles/Computers/Insert Next Expensive Hobby here
Offline JS550
  • IAFF local 1307
« Reply #17 on: June 08, 2009, 06:29:00 PM »
You know though, its not so much the lean of the bike on the stand. The rear tire itself looks strange to me?
Offline Damfino
« Reply #18 on: June 09, 2009, 09:48:22 AM »
Thanks for the replys so far guys. I have some new tires on order and when I take the bike in, I'll have them look at it. BTW, the rear tire is a 130x18 which is two sizes higher than stock so maybe thats contributing to it not looking right? I'm replacing it with a 120x18 instead of the stock 110.
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #19 on: June 09, 2009, 11:19:40 AM »
Anybody thought of this one yet?
Swing arm bushings. To me it looks pretty clear to be in the back tire/swing arm area alone. If you look at the winkers in the rear they are parallel to the ground, however the shocks are not 90 degrees to them. The shocks and the tire are parallel to each other.
Also I have to agree that the center stand looks a little bit narrow. Measure it up and come back with results, we should be able to get a better idea if we can cross it off the list of potentials.
« Last Edit: June 09, 2009, 11:21:30 AM by Sporkfly »
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
