Author Topic: Brighter headlight for 73 CB500  (Read 1594 times)
NoVaCain
« on: June 08, 2009, 07:23:54 PM »
Well, my headlight gave up today, does anyone make a light that is brighter and wont require surgery to the wire harness? The only ones I have been able to find seem to be made for Harley-Davidson's.
adjutis
Re: Brighter headlight for 73 CB500
« Reply #1 on: June 08, 2009, 08:51:01 PM »
I subbed a standard 55/60 watt round halogen from a car on my 550 to replace the stock 40 watt one. Charging system wouldn't carry it all the way, started blowing main fuse, but after dropping the running light portion of front turns and using LED brakelight to conserve power, head light is much more powerful now. No more blown fuses either. Plug was identical on mine, just unplug old and plug in new.
ev0lution7
« Reply #2 on: June 08, 2009, 09:54:44 PM »
Get a GL1100I headlight... (if yours is the 7in round headlight)
goto www.v-leds.com
get a HID conversion kit.. easy to install and will only consume 35watts and you will have a bright headlight really BRIGHT check out my webpage at the bottom of this post you will be very impressed also i had a post about this earlyier... its not hard to do!
