Author Topic: 350F under-the-seat starter switch  (Read 2079 times)
Offline rempy
« on: June 09, 2009, 12:34:01 PM »
I'd like to replace the non-working handlebar starter switch (wire is cut outside of the harness) with a under the seat starter switch. Searching has led me to the fact that some of the CB's route headlight power through the starter switch, some don't. From what I can read on the schematic, the 350 does not. My question :
Is this correct?
Is it just a matter of a switch between the yellow/red and black from the solenoid and a power wire (black)?
And could someone point out a part from Rad Shack or the like that would do the trick? (hopefully one that looks cool ;)
Thanks for the help!
'73 CB350F
Offline OldSchool_IsCool
  • Really feeling like an
Re: 350F under-the-seat starter switch
« Reply #1 on: June 09, 2009, 12:45:55 PM »
Are you talking the key switch (main power) or the starter button?  I don't know the 350 that well, maybe they are one and the same.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline rempy
« Reply #2 on: June 09, 2009, 01:37:15 PM »
The starter button from the R handlebar is what I'd like to bypass.
'73 CB350F
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #3 on: June 09, 2009, 02:23:03 PM »
some bikes kill the headlight while cranking I believe is what he is saying...
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline rempy
« Reply #4 on: June 09, 2009, 04:44:39 PM »
Does your kill switch work or are those wires cut also?
The kill switch does work (current is reaching the coils).
That's exactly what I was trying to say. Thanks for clarifying.
So, would this be the proper setup:
A SPST Momentary switch with the black (power) wire from the harness and the black from the solenoid connected to one of its terminals, and the yellow/red wire from the solenoid connected to the other terminal?
Thanks again for the help guys.
'73 CB350F
Offline razor02097
« Reply #5 on: June 09, 2009, 04:58:02 PM »
You want a normally open switch with an momentary on when pushed.
Project Rina
Offline scooter1
  • 1973 cb750
Offline razor02097
« Reply #7 on: June 09, 2009, 06:52:43 PM »
something like this
http://www.amazon.com/Moroso-74120-Button-Starter-Switch/dp/B000CON4MU
you really don't need something that heavy duty unless you plan on nixing the solenoid.
Project Rina
Offline rempy
« Reply #8 on: June 10, 2009, 09:46:27 PM »
that's is one coooooool looking overbuilt switch. i had to buy it.  ;D
will post pics when it's installed.
'73 CB350F
Offline razor02097
« Reply #9 on: June 11, 2009, 05:20:54 AM »
Keep us updated  ;)
Project Rina
