Author Topic: thank you Mythbusters!  (Read 2980 times)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« on: June 09, 2009, 08:31:12 PM »
on an episode a few years ago, they tested different methods to see which was the fastest way to get beer cold. among those methods were : burying the beer in sand, soaking said sand with gasoline and lighting it (like THAT would work) spraying the 6 pack with a co2 fire extinguisher (worked but at 25 dollars for a charge way too expensive) and one of the more practical ones that actually worked, was putting the beers into an ice/water bath with some salt in the water. the ice and water alone also worked good BUT the salt apparently lowers the temperature that the water freezes making the ice/water bath colder with salt than without. well, i got home this evening from an 8 hour round trip to atlanta this evening craving a few ice cold beers. lo and behold, i hadnt put any of the fresh case in the fridge. i remembered the ice/water/salt thingy and damned if it didnt get the room temperature beer down to 37 degrees in 4 minutes! i was just so damned happy about the icy cold beer that happened so fast i felt the need to share it with a group of folks that i knew would appreciate it. i told my wife about it and i was all excited, her response was, why the #$%* would i care about that? why did you waste the salt damnit! and you folks wonder why i want to get as far away from columbia as i can rotflmfao!
« Last Edit: June 09, 2009, 08:34:21 PM by bucky katt »
Mark Twain - Notebook, 1894
Re: thank you Mythbusters!
« Reply #1 on: June 09, 2009, 08:39:49 PM »
Well I certainly hope they tried the exhaust tubing welded on the truck bumper for cold climate beer cooling.... ;)
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #2 on: June 09, 2009, 08:40:45 PM »
That's an awesome trick. I've heard about it, but never tried it. I have to try it now
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #3 on: June 09, 2009, 08:42:46 PM »
Oh? Do tell!
333:  Think "Shakeweight".
Offline 333
  • Time for change
« Reply #4 on: June 09, 2009, 08:48:03 PM »
We would make ice cream when I was a kid.  I would be the one who had to crank it, no electric one for us.  Ice cream is put in a bath of ice and rock salt.  The salt melts the ice, but doesn't raise the temp, so the water is below freezing point.  And being a liquid, it has a much greater contact area.  My Dad would throw a room temp watermelon in the mix, and would be icy in 10 minutes, all the way through.  A can of soda takes about 3 minutes.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #5 on: June 09, 2009, 08:48:46 PM »
just cut 8 or 10 in sections of tubing, weld on bumper sticking straight up.. insert beer
 betcha cant tell I partied in Malakwa a few times, can ya. :D
Offline Frankencake
  • Yesssssss,
« Reply #6 on: June 09, 2009, 08:53:32 PM »
Does the tubing need ventilation from both ends?  Or does the vacuum do the work?  I suppose negative pressure would take the less dense warmer air from inside the tubing and replace it with denser air.   ??? ??? ???  Am I following this correctly?  I always they were rod holders.....
Offline mick750F
« Reply #7 on: June 09, 2009, 09:11:03 PM »
   Bless you bucky katt!  ;D ;D ;D  Cold beer just got a lot closer and what could be better than that?
Mike
Glosta, MA
Offline OldSkool
« Reply #8 on: June 09, 2009, 09:41:59 PM »
What, they didn't test the Jet Powered Beer Cooler????? What gives?
« Reply #9 on: June 09, 2009, 09:47:53 PM »
I worked on a commercial fishing boat on the Great Barrier Reef and this method is quite well known to fisho's, its called an "ice slurry" and is used to make ice last longer while at sea and it definitely works a treat.
Offline Joel
« Reply #10 on: June 09, 2009, 09:48:19 PM »
Cans or bottles?
Offline bucky katt
    • facebook
« Reply #11 on: June 09, 2009, 10:20:35 PM »
works for either, plastic soda bottles too. i had 6 litre bottles of seltzer in an ice slurryin a styrofoam cooler for my drive to atlanta and back today. the last one was still 38 degrees 9 1/2 hours later when i got back home tonight
Offline Mdub
  • Xspurt
« Reply #12 on: June 10, 2009, 01:35:26 AM »
What is the optimal salt to water ratio?
X= an unknown quantity
Spurt= a drip under pressure!
Offline bucky katt
    • facebook
« Reply #13 on: June 10, 2009, 01:56:31 AM »
i use a fist full of salt per gallon of ice/water mixture. might not be optimal but it works for me.
« Reply #14 on: June 10, 2009, 04:55:42 AM »
We actually used salt water straight out of the ocean, not sure of the ratio of salt to water but it works.
Offline tramp
« Reply #15 on: June 10, 2009, 05:36:36 AM »
god bless the mythbusters
1974 750k
« Reply #16 on: June 10, 2009, 06:37:16 AM »
Actually he was taking about cooling your beer on cold days. The tubing holds the cans out of sight and exposes them to the cold air. I guess technically you don;t even have alcohol in the vehicle.
