Author Topic: Triple tree swap  (Read 17928 times)
SoPackedCustoms
Triple tree swap
« on: June 10, 2009, 08:59:21 PM »
Hey guys new here just curious to see if the cb550 and the cb750 have the same triple tree more or less just the bottom one. are they interchangeable? Thanks in advance
Offline Alan F.
Re: Triple tree swap
« Reply #1 on: June 12, 2009, 07:48:53 AM »
Not sure, but I think the stem is longer on the 750.  Here's a pic of the stem from my 750K3  9-1/2" and 750's stem lengths are the same 69-78 but 77-78 trees have a different offset, use a matched set.
Good luck.
-A
billybobobrain
« Reply #2 on: June 12, 2009, 08:37:17 AM »
although they look the same they are all different, the neck might be the right length but the fork width and rake are likely not the same.
unless you have a triple tree from a 750 on there already it wont work to mix and match.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: June 12, 2009, 10:29:23 AM »
All factory triple trees for CB's have 0 degrees of rake as far as I know, but yes the fork width, size, and offset can all be different from model to model.
mystic_1
- John Augustus Shedd
billybobobrain
« Reply #4 on: June 12, 2009, 12:42:20 PM »
when i replaced the trips on my k2 with k7 they seemed to be different, not only in width (between forks) but rake as well. i could be wrong though
Offline tbpmusic
« Reply #5 on: June 12, 2009, 12:54:16 PM »
This is from my buddy Steve at HondaTwins - so it's good info.
begin quote::
In this post, I'll list KNOWN swaps for customizing....I'll add to the lists
as time allows.....
Forks: 35MM
Pre 79; SOHC CB750/4, SOHC CB650/4, CB550/4, CB500/4, pinch type CB450 &
CB500T.....
ANY matched pair from one of these bikes will fit the trees of any other of
these as tube to tube widths are the same.
"Top-Bolt" 450 forks fit only the original 450 trees (narrower) and SOME
CB/CL 72/77 (305) trees
Forks: 33MM
Early CX 500, CM series 400's/450's, CB/CL360 and "G" model 350's....
"Top-Bolt" 350 forks PROPERLY fit only "top-bolt" trees, but can be used in
later trees (they look "awkward" though)..
Disc-Brake wheels: The 450, 500T, 500/4, 550/4, and 750 disc WHEELS (6-bolt)
are the same and will swap....But rotor size varies, and usually must be
used with the bottom legs (sliders) of the bike it came from, or you can
swap the rotors or sliders.....
The CX 500 and CB 650, and post '77 750 5-bolt rotor wheels, both comstar
and spoked can be swapped, but sometimes requires the axle and spacers be
changed.
Trees: TOP...
CB 450, CB 500T, CB 650/4, and early CB750/4 tops all exchange.....The 750,
650 and 450 (500T) share the identical spacing AND offset (a non-cushioned
750 top tree will fit to a 450 bottom tree (stem and bracket) for those who
desire rigid handlebar mountings.( the 750 stem is longer.and only fits the
750) The cushioned 450 top tree will fit the 650 lower tree and forks if you
desire the "give"....
The 500/4 and 550/4 trees have less offset, but will fit the 450 , 360, or
350 neck ( if someone wants 35mm forks on their 350/360 cafe bike.)
Trees: Bike to bike: 360 trees (350G) will fit any 350, any 360, any CM 400
Variant, and the 450/500T, 500-550/4 and 650/4 necks
450 trees fit 450's and 500T and can be used as a pair on the 500-550/4's or
ANY 350, 360, CM 400, or CB 650
end quote::
Bill Lane
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: June 12, 2009, 04:26:46 PM »
That's not good info, that's totally awesome info!
mystic_1
Offline tbpmusic
« Reply #7 on: June 12, 2009, 05:01:21 PM »
mystic_1
By "good", I mean reliable and accurate.
Steve has his own motorcycle salvage yard, and has actually tried all that stuff, he ain't just blowin' smoke.......
Bill Lane
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: June 12, 2009, 05:30:51 PM »
I knew what you meant, was just being funny :)
Where's Steve's yard?  Info like that deserves a free plug.
mystic_1
Offline MikeB
« Reply #9 on: June 12, 2009, 07:54:07 PM »
begin quote::
as time allows.....
Forks: 35MM
CB500T.....
Forks: 33MM
changed.
Trees: TOP...
end quote::
This is alot of good info
but I'm finding out that the 82 CB650sc Nighthawk has 37mm forks
would Steve have any info on what tees might swap with these, PO had a minor collision and tweaked the forks, got a set off a 81 cb900 coustom that should fit, also 37mm with the same part# for the lowers.
I think the  tees are ok but they will be coming off in the next week or so but if I need to replace was just wondering what might work ?
suppose the ones off the 900 might work but havn't checked that out yet ?
also has a diff steering head angle than the standerd 82 CB650.
29deg. comp. to 26deg 50' is this the RAKE ? that people take about ??
sorry for the dumb ? but seemed like a good thread to ask
fennec
« Reply #10 on: August 12, 2009, 12:31:47 PM »
begin quote::
as time allows.....
Forks: 35MM
CB500T.....
Trees: TOP...
Sooooo.. If I found a cb650/4 triple tree and forks I could throw them into my '74 or '72 cb750/4 ?? Just trying to clear this up... I really want to get those 5 spoke black rims I see on a few CBs....
~Luis
Offline Toxic
« Reply #11 on: August 12, 2009, 02:51:11 PM »
For sure they are different.  I tried to mix a 72 upper with a 77 lower and not a chance.
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: August 12, 2009, 04:42:32 PM »
begin quote::
as time allows.....
Forks: 35MM
CB500T.....
Trees: TOP...
~Luis
It sounds to me like you'll just need the forks, according to this statement:
Forks: 35MM
CB500T.....
mystic_1
Offline riotmachine
  • Live Forever or Die Trying
« Reply #13 on: August 18, 2009, 11:07:56 PM »
So based on this, I wouldn't be able to swap the triple tree top/bottom from a 750 on to my 550/4. Is that correct? If so, there goes my dream of picking up Cycle X's tree setup, I have a top but it is about 2" out from the bottom. It sure is nice a clean.
Scroll way down: http://www.cyclexchange.net/Honda%20Page.htm
If this isnt possible, anyone have any suggestions of something similar?
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: August 19, 2009, 04:33:35 AM »
You could probably swap out the steering stem to make it work, but changing the offset will affect your steering geometry.  Run some rake and trail calculations.
mystic_1
« Reply #15 on: August 19, 2009, 08:50:42 AM »
69 - 76 750 should fit on your 550.
Offline riotmachine
« Reply #16 on: August 19, 2009, 09:23:21 AM »
That's if I get the whole tree and not just the top correct? I had a feeling that was right, just seeing if anyone knows if the stem is too long/short.
Thanks again.
Offline mystic_1
  • 1970 CB750K
« Reply #17 on: August 19, 2009, 09:36:41 AM »
What about this statement from TBPMusic's qutoe?
( the 750 stem is longer.and only fits the 750)
mystic_1
« Reply #18 on: August 19, 2009, 09:47:55 AM »
It will still fit.
 You need a spacer, on top, on bottom , or one on each.
 Or machine threads on stem further, and move top bearing race area, IF that is necessary.
 Will try to look today at length diff, doubt it is a whole lot.
 I think wider tree spacing would be a bit stiffer than the narrower one, may be a good thing.
Offline mystic_1
  • 1970 CB750K
« Reply #19 on: August 19, 2009, 10:15:16 AM »
That makes sense, in fact I thought about that just after I posted.
mystic_1
Offline riotmachine
« Reply #20 on: August 19, 2009, 10:52:19 AM »
It will still fit.
Thanks for info. Looks like I'll go ahead and pick up the rest of the tree assembly. I can get a friend to machine some spacers that'll fit perfect for me.
Next time I'm out visit my family in Penticton I'll popped by since you're so close.
« Reply #21 on: August 20, 2009, 08:56:29 AM »
I did some measuring, its a lot longer that I thought (I figured 3/8 or so, but its mre like 1/2 or +)
 So approx .53 of spacers, or remachine stem (can be done with tree intact)
 Or even better, grind off the stemweld, push stem further into tree (leave enough for race and washer), that should take up most of it, if not 1 washer on the top.
  Riot, where are you at? Def come and visit if you are nearby, phone ahead of time, usuallu around..
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« Reply #22 on: May 13, 2012, 01:18:57 PM »
Hey there old post! So, if I were to buy a 450 triple top, it would be a bolt on on my 750 lower triple tree? I apolagize for digging this one up again, but I've bought some triples online, and none of them fit. So I'm trying to get my info straight.
Offline Roach Carver
« Reply #23 on: June 16, 2014, 01:37:45 PM »
marked
Offline Henkies
« Reply #24 on: December 10, 2017, 01:09:12 PM »
Forks: 35MM
CB500T.....
So does he say that the width of a CB550 and cb750 fork is equal? The offset isn't mentioned, because that differs?
