Author Topic: Oil Pressure swithc alternatives, ideas?  (Read 1832 times)
Offline Hootis29
    • Hootis Motor Sports
« on: June 11, 2009, 08:21:20 AM »
Stock replacement, or curious if someone has come up with a re-placement.
Thanks
Paul " Hootis" Noskowiak
1975 CB 750
1975 CB 550 (Cafe Project)
1973 CL 350
1972 450
2006 Buell Ulyesses
2001 Buell Blast (Custom)
1977 Triumph Bonne
1975 XL1000
1972  750 Commando
Assorted other CB's mostly 500, 550's
Offline Alan F.
Re: Oil Pressure swithc alternatives, ideas?
« Reply #1 on: June 12, 2009, 07:40:11 AM »
It seems like adapting another switch wouldn't be a problem. Just start with the correctly rated switch with the correct threads and go from there, maybe some other bikes use the same switch?
Offline lordmoonpie
    • Moonpie
« Reply #2 on: June 12, 2009, 08:47:52 AM »
replaced mine with a capillary sender to an old style smiths pressure gauge...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #3 on: June 12, 2009, 09:01:04 AM »
Some more info perhaps?
Anyway, another option is the pressure switch from an early 90s Honda Accord. The pressure rating is slightly higher so it will let you know when things are crapping out a little sooner. The only issue I had with the one I picked up was it was a tad tall and the case and switch required some modification.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline eideteker
« Reply #4 on: July 16, 2010, 10:34:11 AM »
I finally cracked the left case today and put an early 90's Accord switch in...I think when I bought it I specified 1990, but it's been so long ago since I've had it lying around I'm not sure (I'll check the part number against Autozone's website and post back the specific year).  Also of note, it threaded in perfectly and isn't leaking, the case required modification as already mentioned, and the oil pressure light is on steady now and won't go off.  Sporkfly, you said the pressure rating is higher - do you know how much higher?  I know there's plenty of oil and I ride the bike quite a bit (no engine damage), so maybe my oil pump gear is shot!  Something else to tear into...  :D
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline CB750Ken8
  • I wanna ride...I wanna ride......Rawr MUST RIDE!
  • It's looking better everyday...jones'n to ride!!!
« Reply #5 on: July 16, 2010, 11:00:57 AM »
I believe he may mean something like this.
78' CB750 K8
« Reply #6 on: July 16, 2010, 03:54:43 PM »
And why not use the original Honda switch for $20, that is correctly rated and doesn't need modification?  ;D
Offline eideteker
« Reply #7 on: July 16, 2010, 04:54:15 PM »
Yeah, I get the gauge idea - I was going with the Accord switch as a stock replacement for the dummy light only.
I was under the impression, from other posts, that the Honda switch was expensive/hard-to-find - so I never even looked!  The Accord switch (PN# PS100) works as far as I can tell, I just think my pressure is low...I'll have to put a gauge on it now anyway to see.  The Honda switch is currently $27.78 on bikebandit.com, the Accord switch was about $8...was it worth cutting into a hidden part of the left case cover?  Probably not, but it's too late now!
Offline nokrome
« Reply #8 on: July 16, 2010, 05:48:03 PM »
  got a pic of how you installed that ?
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
