Author Topic: Fork seal and a spacer?  (Read 1427 times)
Offline nobrake
« on: June 12, 2009, 04:27:56 AM »
Hi
While waiting for the engine parts I decided to rebuild some other parts.
After I took fork seal out I noticed there was a gap between seal and where seal suppose to seat. In another word, seal thickness was 11mm and seal seating depth was 14mm (up to c-clip groove). First, I thought both forks were missing washers. I checked this forum and service manual and it seems there are many variations.
'76 750K
Lower fork is stamped 341
What say you?
Thanks
« Last Edit: June 12, 2009, 04:37:59 AM by nobrake »
Offline Alan F.
Re: Fork seal and a spacer?
« Reply #1 on: June 12, 2009, 07:09:19 AM »
Yup, it's just like you described it, I just seated the seal deep enough to get the clip in position, the rest of that depth is unimportant.
Good Luck.
-A
Offline nobrake
« Reply #2 on: June 12, 2009, 07:17:18 AM »
Thanks, Alan.
Every time I feel like junking this project I get good response like this.  :)
« Reply #3 on: June 12, 2009, 07:26:32 AM »
The early seals were the short ones, later (341) were taller. But if they are aftermarket seals they often come short with a washer.
AS mentioned, you can do without. If they are OEM, someone bot the old seals, which will work in any fork. If one buys the tall seal, it will only work in a later leg.
The taller seals had a third lip to make them seal better.
Offline nobrake
« Reply #4 on: June 12, 2009, 07:43:30 AM »
MCRider-YouR one of the first person who helped me at beginning.
I just wanted to say that right now I am WAY OVER MY HEAD with this project.
You were so correct when you said " just ride it - it's old machine, oil leak and engine noise are fine ".
I just want to reiterate to new comers - JUST RIDE IT!
Once you start unscrewing those frozen screws thinking it will be a weekend job - you will be sooooooooooory.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: June 12, 2009, 07:48:00 AM »
Yeah, I am glad I paused when I was thinking of cracking the engine to change all the gaskets and oil seals out. I tuned it up, new elec. ignition, new coils, cleared up my carb problems witha good cleaning and it purrs like a kitten.
A little oil leak here and there gives it more personality.
« Reply #6 on: June 12, 2009, 07:49:46 AM »
Well that's good and bad. Good you're learning something, bad its riding time. Define a stopping point, get finished up to that point, then ride.
make a list of things to tackle later. Mental or otherwise.
I need to ride a bit more myself.
