Author Topic: Can someone show me pics of carb parts to clean? for a cb500..  (Read 679 times)
Offline Tnutz
I saw a ton, and i mean ton of threads when i searched about carbs... ;D  But i just need to know where the slow jets are and emulsion tubes are for cleaning (have to pulled out i assume?). not used to these silly Keihins.  Links, pics?  thanks?!
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline DaytonGuy
Re: Can someone show me pics of carb parts to clean? for a cb500..
« Reply #1 on: June 12, 2009, 04:49:07 PM »
The simple answer is clean everything.  You should be able to find an exploded diagram of the carbs.  It will show you where the various jets, valves, floats, etc. are.  Take them apart and clean them good.  Use different size copper wire to fit through some of the small passages to clean them all out.
Offline Tnutz
« Reply #2 on: June 12, 2009, 05:51:43 PM »
found one... ;D
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline Johnie
« Reply #3 on: June 12, 2009, 06:04:50 PM »
Here you go from a 750, but you get the idea.  Click the pic to enlarge...
« Last Edit: June 12, 2009, 06:08:22 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
