Author Topic: Cylinder 3's pipe not as hot  (Read 910 times)
2tall
« on: June 12, 2009, 05:02:16 PM »
I am finally getting most of the gremlins worked out of my 76 CB550K. I have one more question for you all. (I'm sure there will be more...)
Cylinder 3 seems to be having an issue. After a ride around the block, 1, 2 and 4's pipes are all hot. 3 is hot too, but not as hot as the others. (On a scale of 1-10, 10 being one of the hot pipes, #3 is a 7 or 8)
I pulled the plug for 3 to see if it was fouled, and it was not. I then rode for 20 minutes and pulled the plug again. Still, no real telling signs of an issue yet it's respective pipe is still not as hot as the others. I then placed the plug against the jug and it did spark. Hmmm...
Any ideas would be appreciated.
Also, how do you attach a pic? I have one of the plug, but I can't figure this thing out.
Offline kghost
Re: Cylinder 3's pipe not as hot
« Reply #1 on: June 12, 2009, 05:08:24 PM »
Image hosting...such as photobucket.
Then you attach the photo as a link.
As for the #3 not being as hot as the others....Have you synced the carbs?
Stranger in a strange land
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: June 12, 2009, 05:29:06 PM »
Swap the #3 plug with another cylinder.  Does the cool pipe follow the plug or does it stay with #3?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #3 on: June 12, 2009, 05:43:46 PM »
What tune-up steps have you done?  Have the tappets been checked/adjusted?  Besides swapping the plug, swap the plug cap too.  Look inside the cap.  Is there green corrosion where the wire screws in?  If so, nip off about a quarter inch of wire.
Sure.
Is it hard?
