Author Topic: OPERATION BIRTH KONTROL  (Read 28073 times)
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
Re: OPERATION BIRTH KONTROL
« Reply #100 on: September 08, 2009, 05:40:51 PM »
and we even have tags now.
Still waiting on some bits and pieces. But we are getting closer. Some one asked the other day about the heat wrap. I used 1 50 foot roll of 1 inch, 1 15 foot roll of 1 inch, and 1 roll of 2 inch by 50 foot.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #101 on: September 08, 2009, 07:59:19 PM »
Wow that is looking really good!!! Love the colors.. Can't wait to see it together and out in the wild.. Nice work..!
Its my Avatar..
75 CB550F  |
  • Mad Fabricator
« Reply #102 on: September 09, 2009, 04:57:40 AM »
Thanks Zaipai.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Alan F.
« Reply #103 on: September 09, 2009, 07:44:06 AM »
Hey RR, did you ever share paint info with us?  I've got another project that needs a red frame...  What did you use for frame paint?
and btw, very nice work.
-Alan
Offline the-chauffeur
« Reply #104 on: September 09, 2009, 10:46:03 AM »
Hey Rusty
Nice build you've got goin' on there.
Where did you get the chrome gauge surrounds from?  I've only ever once seen a set come up on eBay, and although I've found a place that does them for the CB400's, I can't find anywhere that supplies 'em off the shelf.  I thought Carpy might be the man on that one, but even though he uses 'em on plenty of his bikes, I can't see that he actually sells 'em  ???
Thanks for your help buddy, and keep on buildin'.
Neil
  • Mad Fabricator
« Reply #105 on: September 10, 2009, 09:26:54 AM »
Cycle X has them and they also sell them on their ebay store. The are really nice and worth every penny in my opinion.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #106 on: September 14, 2009, 04:08:41 PM »
I went and got a battery, got it all charged up and mounted.
Installed the seat mount.
So then I went ahead and mounted the tail section.
I also got my ISO-PEGS finshed up and mounted. they look way better than the stock ones in my opinion.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #107 on: September 14, 2009, 04:32:22 PM »
Looking really good!!! Where did ya get those pegs?
Its my Avatar..
75 CB550F  |
  • Mad Fabricator
« Reply #108 on: September 14, 2009, 05:28:16 PM »
They are kuryakn iso pegs for a harley davidson.
« Last Edit: September 15, 2009, 07:16:19 AM by rustrocket92 »
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #109 on: September 14, 2009, 05:43:39 PM »
Small ISO Pegs $40
Large ISO Pegs $45
PM me and I can give you shipping quotes.
Rusty I never thought to use them on a CB.... Very nice man. Very nice indeed. I'm jealous of the idea.  ;) :D ;D
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
  • Mad Fabricator
« Reply #110 on: September 15, 2009, 07:29:48 AM »
I got them from dennis kirk for like 42.00 plus shipping. I was ordering other things so the shipping wasn't bad. The pegs are for a Harley Davidson not quite sure what model.
  Part# H49600
Small Male Mount ISO-Pegs
I contacted Kuryakn and let me tell you they were NO-HELP what so ever ! I explained what I was doing ( pictures and dimensions included ) And all I ever got was " I asked the techs and No nothing for your application "
So i took matters into my own hands. I ordered the above set of pegs. I then went to Lowes and purchased two 3/8 pins , two 3/8 bushings ( steel sleeves ). I cut the sleeve to fit inside the honda peg mount. The I drilled the honda peg mount to accept the 3/8 pin. Then I drank a couple beers and drilled the peg adapter to accept the bushing. Put it all together and then welded the bushing to the bottom of the  iso-peg adapter. When you install the peg into the honda peg holder it does not sit level it points down. So I welded a small strip of steel along the bottom of the Honda peg holder to keep it level. You could also drill a hole in the bottom and run a small bolt up thru to use as an adjuster so the peg sits even. I will get you some better pictures if needed.
Hope this helps for others trying to get rid of those awful Honda pegs.
« Last Edit: September 15, 2009, 07:34:51 AM by rustrocket92 »
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline HavocTurbo
  • Can you tell?
« Reply #111 on: September 15, 2009, 08:59:30 AM »
Ok Here's what the Kuryakyn guy told me...
Small ISO Peg - 4" long and 1.5" wide.
Large ISO Peg - 4.5" long and 2" wide.
Looking at them in pictures and holding in his hand he said there is a huge difference between the two in size. Must be the rubber pads that does it.
Evidently the small difference in numbers is irrelevant.
09 XL883L - No Name
  • Mad Fabricator
« Reply #112 on: September 15, 2009, 09:57:27 AM »
I used the small peg and harley adapters.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #113 on: September 22, 2009, 05:07:13 PM »
I figured I would post some before pictures so everyone could see my $300 purchase before I tore it apart.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #114 on: September 22, 2009, 07:51:01 PM »
Man, I see so many posts about $300 finds, I have yet to see one.. I bet I just live in the wrong area.. Good luck with that new addition..
Its my Avatar..
75 CB550F  |
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #115 on: September 22, 2009, 10:18:04 PM »
how about 3 bikes for $100 bucks lol and they all ran before they where stored. and ive only spent 300 to get one running and I have 2 in my garage waiting to be built.
Keep it shinny side up.
  • Mad Fabricator
« Reply #116 on: September 23, 2009, 03:38:38 AM »
I got my 1976 for $300 it took about 3 days to get it running, my 1978f for $100 dollars in boxs and my 1973k for nothing and it took about 4 days to get it running. So $400 for the three I think was a pretty good deal.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #117 on: September 23, 2009, 05:39:47 PM »
Yup. I must be in the wrong part of the country.. I think I better move to the west coast or the east coast before they are all gone! ;)
Its my Avatar..
75 CB550F  |
Offline Operator
  • Someday I will live up to being a
« Reply #118 on: September 24, 2009, 05:56:10 AM »
Very cool, love the white fairing and hardbags!!!!
If you are ever looking for a new home for the hardbags, my '73 K3 that would provide them with a nice trip around the Canadian countryside.
If ever there was a creator of bastard sons, it is the open road, for she has claimed so many young men yearning for freedom......
1973 CB750 K3
1976 CB400F (Cafe Project)
1979 Yamaha XS400 (Currently up for Sale)
Offline honda_jason
  • I have no idea what I'm doing
  • 1971 CB500
« Reply #119 on: September 24, 2009, 02:08:53 PM »
i landed my 71 cb500 for $100 and it started without even doing anything!
needed a ton of work but im into it $600 and its almost done, but i have all the parts...just gotta get off my lazy butt and do it.
none the less this bike is sick. love the motor.
  • Mad Fabricator
« Reply #120 on: September 24, 2009, 04:24:49 PM »
Thanks Jason.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline honda_jason
  • 1971 CB500
« Reply #121 on: September 26, 2009, 10:50:40 AM »
the more i look at this thread the more obsessed i am with your bike. haha. i love the motor and everything. how bout i ship my motor to you and you can just do it for me? haha. if youre ever in new england with this beast lets go for a ride!
  • Mad Fabricator
« Reply #122 on: September 28, 2009, 06:41:08 PM »
Well I got a lil more work done this weekend. Still have sum shaping to do on the seat padding. I still have to make a small bracket to mount the breather filter and finish my kickstand. But here are some more pictures.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #123 on: September 29, 2009, 05:32:06 AM »
I really like it so far... Really good work. Well worth the wait.. Keep em coming..
Its my Avatar..
75 CB550F  |
Offline HedNut
  • Underwater Basket Weaving
« Reply #124 on: October 02, 2009, 10:15:46 AM »
Killer setup... Helmet and bike! Nice
Are you leaving the seat just foam!?....sans apholstry.  I kinda like it!
