Author Topic: OPERATION BIRTH KONTROL  (Read 25778 times)
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
Re: OPERATION BIRTH KONTROL
« Reply #50 on: July 15, 2009, 02:30:54 PM »
Thanks Toxic! that is what I wanted to hear. I have to get some piston rings first before I reassemble. They are availible from bike bandit which realy upsets me because I just placed an order with them and it was already shipped.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #51 on: July 16, 2009, 04:13:09 PM »
I was really hoping to have a rolling chassis by the weekend but it doesn't look like it is going to happen unless i put the fork lowers on and reuse the old piston rings. I recieved all my triple tree bolts and nuts, brake caliper screw and spring, and rear shock nuts and bolts today.  So maybe I try to tackle the wiring harness and finish up the motor this weekend. Or maybe i will ride JETSKI and DRINK BEER !
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
poomwah
« Reply #52 on: July 16, 2009, 07:26:41 PM »
you advertising the kylon camo paint :]  I've heard some pretty good things about it.  Is that what you used on your water craft?  I've been thinking of buying a gallon of it and spraying my bronco II
  • Mad Fabricator
« Reply #53 on: July 17, 2009, 10:23:19 AM »
I used that camo paint to paint my jetski and i use it for my ar-15 mags. It has held up very good on the jetski.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #54 on: July 20, 2009, 04:06:55 PM »
I know i saw a topic about wiring xs 650 switches onto honda's but i can't find it anywhere. I have my harness pretty much straightened out but i am probaly going to need a new left side switch unit because there is something wrong with everyone i have.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline turninwheels
« Reply #55 on: July 23, 2009, 10:03:35 AM »
looking great keep posting...bummer about the forks though
"high powered suicide machine."
  • Mad Fabricator
« Reply #56 on: July 23, 2009, 05:42:15 PM »
So i started checking out the harness and looks pretty good everything seems to be ok. When i hook a battery to it the headlight, horn, turns, and brake light all work. I have power everywhere i should.
It's starting to look like a motorcycle again. I can't wait to get the motor back in and get it all wired up.
I am waiting on looks of parts from BikeBandit, Partsnmore, and alreadt got my stuff from Z1 Enterprises. Hopefully it will be here before the weekend.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline cafeconleche
« Reply #57 on: July 24, 2009, 07:32:48 AM »
Rustrocket,  what model/size tires do you have?  Looks like they're Dunlops.  I'm digging them, they look super aggresive
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
« Reply #58 on: July 24, 2009, 07:42:50 AM »
It's lookin slick man, can't wait for the finished product
  • Mad Fabricator
« Reply #59 on: July 24, 2009, 11:38:54 AM »
the rear is a 16 inch dunlop qualifier not sure about the front but will check when i get home.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline DaytonGuy
« Reply #60 on: July 26, 2009, 06:30:01 PM »
Where did you get the grips?  They look pretty sweet.
  • Mad Fabricator
« Reply #61 on: July 27, 2009, 05:08:54 PM »
well I got the front forks back on complete with new seals , boots , and piston rings. I have to get some springs and fork oil. ANY OIL RECOMMENDATIONS ?
I am considering just installing the small dust boots and using the long ones for something else.
I also started working on my switch pod.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #62 on: July 31, 2009, 03:38:06 PM »
Switch pod is done and ready to be wired up. Hoping to get the motor back in this weekend.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #63 on: August 04, 2009, 05:22:10 PM »
Now we are getting somewhere.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline BIKE
« Reply #64 on: August 07, 2009, 05:31:33 AM »
This build is awesome.  Just wanted to say. ;D
1975 CB750 K5
1977 CB750A
  • Mad Fabricator
« Reply #65 on: August 07, 2009, 09:33:41 AM »
Thanks bike! It is startin to come together.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline ridgeline61
« Reply #66 on: August 13, 2009, 06:41:52 PM »
Where did you secure that license plate bracket to?
BTW nice bike! Switch pod is killer!
  • Mad Fabricator
« Reply #67 on: August 13, 2009, 07:21:36 PM »
I made the plate bracket out of a piece of pre-bent steel I had laying around the garage. It is mounted to the upper shock bolt and has a rubber bushing at the bottom to keep it from hitting the coil spring.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #68 on: August 14, 2009, 09:40:22 AM »
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
« Reply #69 on: August 17, 2009, 07:20:01 PM »
Well I am sittin around and waitin on the mailman, the fedex man, and the ups man !
So here are some pictures to keep you busy. ( cue the elevator music )
Engine is in so I had to sit the tank and tail on it just to check it out.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Zaipai
    • My Home page
« Reply #70 on: August 17, 2009, 07:55:29 PM »
Spectacular job. Great attention to detail.. Man that's going to be a sweet ride when you are done.
Its my Avatar..
75 CB550F  |
Offline bzr
  • I'm not here.
« Reply #71 on: August 17, 2009, 11:26:27 PM »
I want a switch pod like that in my life.  8)
1976 Honda CB550F
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #72 on: August 20, 2009, 05:25:36 AM »
That is a great vision and a pleasure to behold. :o
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline checkflag
« Reply #73 on: August 20, 2009, 06:38:29 PM »
Love the build.. looks great..
Excuse my being ignorant, but what is that switch pod for? it looks
so fighter jet cool!
1979 cb650. Mac 4-1 exhaust. Soon>> cb750 carbs.
  • Mad Fabricator
« Reply #74 on: August 21, 2009, 09:24:40 AM »
Thanks checkflag. The switch pod is for the headlight and power to the coils.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
