Author Topic: Needed Pic Of rear F Shock mount on frame  (Read 831 times)
Offline Burke
« on: June 13, 2009, 12:58:47 PM »
When taking the shocks off my 75 CB750F, The lh bold came out hard and the rh just snapped :o. Before I start into them I want to get a clear pic of what they are suppose to look like so I dont destroy everything.
Also I was almost sure that my old K model had the bol studs welded to the frame, is this right or am I high. :D
Thanks
Re: Needed Pic Of rear F Shock mount on frame
« Reply #1 on: June 13, 2009, 07:30:44 PM »
Yes, they are welded to the frame.
Easy fix, is to drill and tap them and insert stud, then you can re-use the Acorn nut.
Offline Burke
« Reply #2 on: June 14, 2009, 04:37:33 PM »
Here is a pic of what I am dealing with. The small hole in the center is a hole I drilled to try to get an easy out in. As well as the bolt that was there
So I should drill these out, tap them and then insert a stud or just use a bolt or would it matter?
Offline Burke
« Reply #3 on: June 14, 2009, 04:40:28 PM »
Plus I wanted to thrown in a pic of my Triple tree top. I thought I did a decent job with the polish. ;D
