Author Topic: Alfredo Sauce  (Read 1316 times)
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
Alfredo Sauce
« on: June 14, 2009, 10:19:54 AM »
I recently picked up this 1972 Suzuki T350. It's a two stroke.
One of the noteworthy things is it has fabulous compression. Anyway I pull the heads to see what I see. The top of the pistons are covered in this substance that looks like Alfredo Sauce. It is oderless and apparently not water based, else the cyclinder walls would be rusting.
I clean up the piston tops and head. Kick it over a few times and I don't see anymore appear. I reassemble heads and put in spark plugs. I kick it over about 10 times. Now I remove the heads again. Again the top of  the piston is saturated with this Alfredo sauce...
Clearly it's in the crankcase and such as the way a 2 stroke works it would pull it up.
I've seen oil and water mixed, but this isn't it... This stuff is a clean, consistent substance. I just can't figure out what it is. Why it's there is a different question. I'm wondering if it might have been put in intentionally as a means to preserve the engine.
Anyone have a clue????
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Alfredo Sauce
« Reply #1 on: June 14, 2009, 10:35:07 AM »
White Lithium Grease?
Used to be a fairly cheap replacement for assembly lube. At least for cars. Never heard of it being used on a smoker though.
Does it feel like grease? Or maybe it's degraded 50:1 mix. Like 20 years degraded.
Sounds to me like it could use a good flushing with some hot 5w30.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Bodain
Re: Alfredo Sauce
« Reply #2 on: June 14, 2009, 11:59:50 AM »
Well I found a drain plug for the crank at the bottom of each cyclinder. Shot some kerosene into the side ports with the piston at it's lowest position to clean it out.
2 hours later this old bike is a running.
2009 Suzuki TU250
2014 Honda Grom
2005 Yamaha Zuma 50
1974 Honda CB 750
Offline 750goes
  • it will live
Re: Alfredo Sauce
« Reply #3 on: June 15, 2009, 11:19:18 PM »
Was there lots of sauce still in it ??
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Alfredo Sauce
« Reply #4 on: June 16, 2009, 03:59:19 AM »
i need to finish the k4750 so i can get my Titan (t500) torn down and repaired. how fast does it feel as compared to our honda 4's?
Mark Twain - Notebook, 1894
Offline Bodain
Re: Alfredo Sauce
« Reply #5 on: June 16, 2009, 06:13:17 AM »
There wasn't really much in it, but enough to to be pulled up from the crankcase and coat the top of the piston. Still a mystery about what it is and why it's there.
The Suzuki T350 was an interesting find, not because it remarkable in any peticular way, but because of it's rarity. I've seen Suzuki's T250's and T500's for sale now and then. I've never ever seen a T350 for sale. When I got it. I searched every city in the US on CL to see if there were any others. I found one in the entire US in California.
Two years ago I rode a friends restored T500. The vibration coming up from the handlebars was just about unbearable.I expect the T350 to be about the same. Parts for the T250 and T500 are around,but very little to choose from for the T350. Fortunately many parts are the same.
This T350 isn't actually running and ridable. I had just done some basic work and wanted to see if it would bark. So I've replaced the point system, bought a new coil, worked the carbs just enough such that it should run, removed the Alfredo Sauce and I heard it bark for about 15 seconds, then shut it down. I guess I'll get serious with it now.
2009 Suzuki TU250
2014 Honda Grom
2005 Yamaha Zuma 50
1974 Honda CB 750
Offline Inkscars
  • grumpiness comparable to an
Re: Alfredo Sauce
« Reply #6 on: June 16, 2009, 06:15:56 AM »
Is that thing cooled via radiator or air?
81 Hardly Davisson
Offline bucky katt
    • facebook
Re: Alfredo Sauce
« Reply #7 on: June 16, 2009, 04:01:57 PM »
air cooled. 2 cylinder 2 stroke
Offline Inkscars
Re: Alfredo Sauce
« Reply #8 on: June 16, 2009, 04:02:28 PM »
Weird. I've got nothing.
81 Hardly Davisson
Re: Alfredo Sauce
« Reply #9 on: June 16, 2009, 11:04:47 PM »
Was common this side of the pond. mostly same as T250 (also known as the super six) except for barrels/pistons and carbs(maybe only jets --not sure)
