Author Topic: Ducati Monster - and maintenance  (Read 4947 times)
Offline gregimotis
  • poet laureate; SOHC4.
« on: June 14, 2009, 03:05:12 PM »
What's the scoop - do they need work all the time?  Can I realistically do a tune up without buying a ton of tools?  That stuff.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Ducati Monster - and maintenance
« Reply #1 on: June 14, 2009, 03:21:07 PM »
What year? A lot has changed in the past few.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline gregimotis
« Reply #2 on: June 14, 2009, 05:28:15 PM »
I'm looking at a 2001 m750 but am shopping around.  I don't mind a little work, and everything needs maintenance - but I've already got an ongoing project in the CB.
Offline bucky katt
  • i am a pastafarian!
    • facebook
Mark Twain - Notebook, 1894
Offline gregimotis
« Reply #4 on: June 14, 2009, 08:50:57 PM »
http://t-shirts.cafepress.com/item/white-tshirt/281435829?CMP=CJ-CLICK-10463747
That's the rumor - I'm hoping some of the guys with Duc's will come along and give it to me straight.
Offline CBGhia
« Reply #5 on: June 14, 2009, 09:26:32 PM »
There is a video you can buy that shows you how to adjust the valves.  You will also need a micrometer.  you can pick one of those up on ebay fairly cheap.   Honestly though I only had one valve out of spec after 12k miles on my M750.
Aside from the valves, there is no difference between a Ducati and any other bike.
I miss my Ducati (sold it just before my son was born) and i hope to pick up another one later this year or next.
Offline HavocTurbo
  • Can you tell?
« Reply #6 on: June 14, 2009, 09:38:47 PM »
I had a 96 900SS. Which at the time was basically the same thing as the monster only more involved.
Make sure you change the serpentine belt every 20,000. Oil every 3-5,000. And adjust the valves before every season.
I have never had any problems doing that maintenance. Had lightened flywheel and crank. HD valve springs and Ti retainers.
Monsters are expensive to fix if they break, but take care of it and it will never happen.
09 XL883L - No Name
Offline KB02
« Reply #7 on: June 15, 2009, 04:23:23 AM »
I've got a 2000 M750. I LOVE my Duc. Valve adjustments every 6000 miles. I change my oil every 2000 miles, not 3-5 - but that's me. And then the belts every 18000-20000 miles. I'm finishing my second SOHC Honda complete engine rebuild and and just too chicken sh!t to adjust the valve on my Duc. That may change, though, as y local dealer is no longer a dealer and the next closest dealer is 4 hours away.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #8 on: June 15, 2009, 06:06:16 AM »
We race Jons 03 monter 800. He does very, very little maintenance on it. Not to say it shouldn't have more.... but it hasn't blown up yet....
No.
Offline CBGhia
« Reply #9 on: June 15, 2009, 08:00:33 AM »
Honestly,  the first time I adjusted the valves, I was terrified, but not so much that I wanted to pay big money to a dealer to do it for me.  Honestly the video helps sooooooo much.
Offline CBGhia
« Reply #10 on: June 15, 2009, 08:09:21 AM »
Oh and check these guys out (like you need another forum)
www.ducatimonster.org
This is the best Ducati forum I have ever found.
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #11 on: June 15, 2009, 08:40:59 AM »
One little point to consider. Most Asian bikes have a wet clutch, that seems to last forever. If you do replace clutch plates it's about $50.00 to $60.00 bucks for almost anything.
Most Itialian Harleys have dry clutches that don't last anywhere near forever. When it's time to buy new ones, which is frequent relative to wet clutch bikes the price is about 3 x what you would pay for clutch plates on any Japanese bike.
3X is about par for Ducati anything.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
  • Be careful you might get a
« Reply #12 on: June 15, 2009, 08:48:12 AM »
I'm glad to here it's not as bad as I'd previously been told. Somebody once told me the belts needed to be done every 6k miles and it was $1200 + to have a mechanic do it. I was pretty skeptical but ya never know until you here it from an actual owner.
Offline gregimotis
« Reply #13 on: June 15, 2009, 09:17:48 AM »
+1  I'm not afraid to learn and do maintenance.  I am afraid of $1,200 repair bills.
Offline HavocTurbo
  • Can you tell?
« Reply #14 on: June 15, 2009, 09:22:12 AM »
Even riding mine hard and doing lots of hard clutch popping I never had to replace my clutch in the 6 years I owned it.
If you've never ridden a dry clutch before you might burn one getting used to the feel, but after that they are pretty easy to make last a good long time.
09 XL883L - No Name
Offline KB02
« Reply #15 on: June 16, 2009, 05:07:56 AM »
Last fall, I dropped my Duc off at a dealer for full tune up, valve adjustment and new belts. Total cost, around $650. The M750 is only a two valve per cylinder engine. It's when you get into the fully faired four valves that you end up with the $1200 service tags.
I believe you will find the 2001 M750 has a wet clutch (my 2000 does). A.) Lasts longer. B.) Sounds better.  ;D Those dry cluches are rattly things.
And, uh... yeah... that sounds about right.  ;) :D :D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline lordmoonpie
    • Moonpie
« Reply #16 on: June 18, 2009, 04:48:37 AM »
If you're mechanically savvy you can do the work yourself. I change my 888 SP5 belts every 12,000 miles or 3 years - they degrade over time and it's not worth the risk.
The comments so far on clutches are frankly not correct. My 888 shares the same clutch basket as later 999 models and the plates are 10% cheaper to buy than for my Honda VTR1000 and as it's a dry clutch, you can change it yourself in under 5 minutes flat and that's stopping for a cold beer in the middle!
Oh - noisy clutches are a Ducati characteristic and worth lettign the noise out - after all a dry clutch gives you more horsepower to the back wheel than a wet clutch so you might as well let people hear it.
Italian Harley? - get outta here! Ducati's are bristling with technology whereas Harleys seem to be as technologically advanced as your average 1920's farm tractor!  :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline KB02
« Reply #17 on: June 18, 2009, 04:51:55 AM »
Being kind of generous to Harley, aren't you?  ;) ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline HavocTurbo
  • Can you tell?
« Reply #18 on: June 18, 2009, 08:32:25 AM »
I know I have a 48 lawn mower and for some reason they messed up and insted of John Deere all over it it's got this Davidson fellow's name on it.
09 XL883L - No Name
« Reply #19 on: June 18, 2009, 10:37:49 PM »
got a pic?
Offline Owned
    • Finished Product
« Reply #20 on: June 19, 2009, 11:28:24 AM »
I own an '01 900ss.  Bought new and currently has 19k miles.  Nothing on this bike has broken yet.  As mentioned earlier, clutches are simple and cheap to replace.  Belt replacement isn't hard for that matter either.  I've not done my valve's on my own...it is a costly service at the dealer.
I'll never sell it.  It's too much fun.  Great for track days.
...on the right.
'01 Ducati 900ssie
'74 Honda CB350F
http://www.flickr.com/photos/indyrider/sets/72157619944545142/show/
'73 Honda CB350/400F Hybrid
http://s1231.photobucket.com/albums/ee520/indyrider2/?albumview=slideshow
'64 Honda CB160 Soon to be unveiled!
Offline HavocTurbo
  • Can you tell?
« Reply #21 on: June 19, 2009, 04:40:37 PM »
got a pic?
lol it was meant to be a joke. I'm sorry. I'll PM you a pic of the bike as it was 10 years ago.
09 XL883L - No Name
Offline schwebel
« Reply #22 on: June 23, 2009, 06:27:27 AM »
There is a lot more maintence on an old sohc4 than a Duc. If you can handle a sohc4, then you can handle a Duc.
Offline MikeDeB
« Reply #23 on: June 25, 2009, 10:43:14 PM »
I have 2 Ducatis.  One a 98 M750 and a 97 900SS.  Love them both.  Maintenance is every bit as easy as a SOHC just different.  There are lots of resources out on the web for maintaining a Duc.  I've done all the maintenance on mine which is everything from oil changes to valve adjustments and belt changes.  If you buy a used Duc make sure the belts have red printing on them (letters, numbers and graphics).  This signifies they are Kevlar reinforced.  White printing will be older original belts without Kevlar reinforcement (they break).  My Monster is fast approaching 30K and is as reliable as the day it was new.  It's also been modded a bit.  And it's a joy to ride.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline mgmuellner
« Reply #24 on: June 27, 2009, 10:57:24 PM »
I've owned a few Ducati's.  Bevel 900SS, 95 900SS, 02 M900.  The monster was a fun bike.  Certainly no different maintenance wise than any other bike I've owned.  Except for belt replacements (easy) & valves (do-able).  Prices for parts on the monster are no worse than other modern bikes.
73 CB750
69 CB350
73 RD350
73 z50 (2 of em)
01 SV650
