Author Topic: 350 igition question  (Read 2076 times)
Offline Green550F
  • Nothing is as cool as that which you made.
« on: June 15, 2009, 06:06:36 PM »
I'm considering making an upgrade to my cb350 ignition. I have a bad coil and may try to change over to CDI.
A few questions I have are:
Is there anything suitable out there?
Am I correct in thinking the plugs fire at 270/90 degrees from each other.
Do the plugs fire on opening or closing of the points?
How much dell is there in the points system?
I'm confident I can build an ignition circuit If I have enough info...
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline heffay
Re: 350 igition question
« Reply #1 on: June 15, 2009, 06:10:56 PM »
was looking for something else but got distracted by this
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
« Reply #2 on: June 17, 2009, 02:41:42 PM »
The plugs fire when the points close. When they open, current flows into the coils and builds up a charge. This charge gets pretty big, then the magnetic field  collapses upon the points closing and you have some 20,000 volts run to the spark plug.
My manual doesn't mention a dwell setting, just timing and points adjustment.
Offline tbpmusic
« Reply #3 on: June 17, 2009, 03:22:14 PM »
It's a 180 degree twin, with all that implies.
Lot of headaches converting - why not get aftermarket coils from Mike's XS Shop.
About $60 for new coils/wires/caps, and it's virtually a bolt-up.
Bill Lane
Offline kirkn
« Reply #4 on: June 18, 2009, 01:21:30 PM »
Normal battery-and-coil, points-type ignitions spark the plug when the points OPEN.  When the points are closed, the current flows thru the primary winding in the coil thru the points to ground.  This current flow builds up a magnetic field in the coil.  When the points open, the current flow stops, the magnetic field in the coil collapses cutting thru the secondary windings as it does so, inducing a current flow which jumps the plug gap to ground.
Offline Green550F
« Reply #5 on: June 18, 2009, 07:27:37 PM »
I was thinking they fired when opening...
Also how can it be 180 out of phase when the point's are at 90 derees from each other?
70 Honda CL350 Cafe
Offline Jay B
« Reply #6 on: June 18, 2009, 08:27:36 PM »
The crank is 180 out of phase, IOW, one piston is down when one is up. Cam is driven 1/2 crank speed, therefore points fire 90* apart on the cam. And yep that results in an uneven firing order. They fire at 180* then 540*. (It takes two revolutions per combustion cycle on a 4 stroke) Old Triumphs used 360* cranks, pistons rose and fell together, and fired every 360*, giving an even firing order.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline rchrdms
    • Richard F Meese
« Reply #7 on: June 19, 2009, 01:26:42 PM »
OK, I guess it fires when open. I should remember,  many times I've lined up the timing marks with the points just as they open.
BTW, the Clymer manual has a cool method for aligning the timing on your bike. You connect a test light lead to the terminal of the points for
the cylinder you are adjusting and connect a jumper clip to ground. The light shines when the points open, and you can adjust the timing by moving the breaker
plate advance or retard timing.
Offline tbpmusic
« Reply #8 on: June 20, 2009, 07:27:32 AM »
Go here for the timing process on your bike -
http://www.hondatwins.net/forum/viewtopic.php?f=18&t=883
Bill Lane
Offline Green550F
« Reply #9 on: June 20, 2009, 06:05:07 PM »
What a relief! The failed left spark turned out to be a bad plug and not the coil!
This buys me time to make a CDI setup. I'm going to try and design a setup that'd be "universal" as a set of honda points...  ;)
Once done, maybe I can recoup some of the cost by selling my stock ignition.
Otherwise, Here's the bike!
70 Honda CL350 Cafe
