Author Topic: Question about rear sprocket hub compatibility.  (Read 781 times)
thirdeyeopen23
« on: June 15, 2009, 09:04:24 PM »
Hi, I was in need of a new rear sprocket hub for my 78 cb750k and i was wondering if any of the other years/models of the cb750 have a sprocket hub/assembly  that can be used on my bike. thanks in advance.
Offline burmashave
  • Forum Immoderator
    • burmashave.net
Re: Question about rear sprocket hub compatibility.
« Reply #1 on: July 02, 2009, 11:28:55 AM »
The rear is a 41 tooth, and as near as I can tell, it was only also used on the '77 CB750K. If you replace one sprocket (new), you should really replace both. The front is a 15 tooth, and it has the same compatibility. I just replaced both on my '77 CB750K.
Quote from: SOHC Digger, RIP
'77 CB750k
